How well does air flow through grille cloth vs dust?
Old Mar 11, 2005
J187's Avatar
J187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of light
Long story short- I am considering leaving the side car computer wide open to ventilate the CPU, I want to protect it from dest though, I 'm thinking about using grille clothe. Anyone?
Old Mar 11, 2005
Just use a fan. It will keep dust from building up. You can always take it out every once in a while and air dust it too, right?
Old Mar 11, 2005
Wisper's Avatar
Wisper is an unknown quantity at this point
If you want to filter the dust, and the area you want to cover is not too big. Use a sheet of fabric softner as a filter with a fan. It is a quick way to trap dust and doubles as an air freshner.
Old Mar 11, 2005
J187's Avatar
Thank you. I definitely will use a fan, but in a trunk during the summer, a 40mm Case fan isn't going to cut it. I'm also trying to cut down on the number of powered devices I'm using - I've only got 150w to work with and I dont' like the idea of the hogging that power with fans.
Old Mar 11, 2005
MegaHurtz's Avatar
i imagine that it flows air very well as i have heard another member of this board say that it was "100% acoustically transparent".... as for dust, well I imagine not so well as the particles would have to be super super small to fit thru the mesh of the cloth
Old Mar 11, 2005
J187's Avatar
^^^^ That's what I was hoping. Thanks for the input Mega
jzhartman
22
Jul 23, 2015 10:42 PM
Jul 12, 2015 11:54 AM
silentz
Jul 9, 2015 08:16 PM
Bounddyy
Jul 8, 2015 11:22 AM
