I'm trying to buy some wire for the dash buttons.
Old Mar 1, 2005
909's Avatar
909
909 will become famous soon enough
Every button on the center dash is being moved to another area of the car.
The buttons include AC/heater/fanspeed assembly, AC/recirculate/reardef assembly, and the all mighty "look at my hazards from my taillights" button.
Can anyone suggest where to buy wire, what type to buy, what to look out for and what to avoid. Thanks in advance.
Old Mar 1, 2005
darklegacy540's Avatar
darklegacy540 is on a distinguished road
Since everything will be inside the car, you can use basic copper multi-strand.. 16-18 awg will be just fine. You can get a whole spool from just about anywhere for about $20. Home Depot, Pep Boys, wherever.
Old Mar 1, 2005
909's Avatar
909
Thanks , Good response. I was over worried.
Rep for you.
Old Mar 2, 2005
PopcornPlaya's Avatar
Electric Boogaloo...
I might step up to 16-14 gauge if you were making a decent amount of lengthening. To account for line loss of course.
Old Mar 2, 2005
profuse007's Avatar
Senior Member
profuse007 is an unknown quantity at this point
home depot do not carry those type of wires, the closest to them are the speaker wire which are too heavily insulated.
try partsexpress.com just stick to ~18 guage is good enough. you dont want to have too big of wires thatll make harder to run though.
Old Mar 2, 2005
dinglenuts's Avatar
dinglenuts is an unknown quantity at this point
a larger guage wire is totally unneccesary unless your running like 60 feet. Just match the guage you've got.
Old Mar 3, 2005
Thanks for the rep.. yes you were over worried.. yeah I wouldn't use anything bigger.. its going to be running like what... 4 feet tops?
Old Mar 3, 2005
J187's Avatar
J187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of light
wow, I'll be the first to ask, where you putting it all? Your options are limitless, like Sarah-michelle Gellar said, You can put it anywhere! Personally, I was going to put the Recirc, rear def, and ac button console in that tiny rectangle pocket in the console in front of the armrest.
Old Mar 3, 2005
sivlercivic02cc's Avatar
sivlercivic02cc is an unknown quantity at this point
User Cat 5 cable 8 strands in each wire, makes it real easy!!!
Old Mar 3, 2005
909's Avatar
909
12+ hours of soldering.
Ok I finally did it.
Thanks for all the help.
pincookie1
May 4, 2015 12:22 PM
nicholaai
Apr 27, 2015 05:54 PM
SSMatey
Apr 13, 2015 06:09 PM
