Installing hyper white leds to replace stock led's
Old Feb 25, 2005
Blahman2's Avatar
One Slow Civic.... But I can take turns pretty well :-)
Blahman2 should not be trustedBlahman2 should not be trustedBlahman2 should not be trustedBlahman2 should not be trusted
I just want to say, if your not good with solder and such don't even attempt this... Its very hard and easy to mess up.
Its also a head ache... gotta run out to the car to test the damn things 20 million times. So unless you know what your getting into don't do it.
My conversion is almost done, I'll have pics asap. Got two more led's to get workin.
Old Feb 25, 2005
Lol. I just ran new wires and put in leds that way. Kinda a mess back there but it works. Let's see them pics!
Old Feb 26, 2005
Blahman2's Avatar
install is almost complete. I just need to fix one led. gearbox. Did you notice different brightnesses of some of your leds?
Old Feb 27, 2005
well yea because of the way it's set up. I put two leds for each bulb for the dials and it's still dimmer than the buttons that I put one led in. It's not gonna be perfect I guess. Still okay. They got dimmer after aem pullies install.
Old Feb 27, 2005
Blahman2's Avatar
wouldn't installing a nice big capacitor fix your dimming problem? cause it holds power and helps power junk.
Old Feb 27, 2005
i have that hvs thing. the dimming just happens at idle cause the alternator is underpowered. The led lights under the seats really dim no matter what like opening the window.
Old Feb 27, 2005
Blahman2's Avatar
led lights under the seat?
Old Feb 27, 2005
Ya cause neons keep dying on me. I got those 8 led apc things that are small capsules. I only used two per side and they're super bright.
Old Feb 27, 2005
Akutenshi's Avatar
The Rizing Sun
got pics?
Old Feb 27, 2005
Not installed, but basically I put two capsules under each seat facing forward. Any more and it was just way too much light compared to my dash lights. For the rear part of the seats (visible from the back), I have EL string light along the bottom. It looks pimp but hard to take pics.
Old Feb 27, 2005
Akutenshi's Avatar
The Rizing Sun
hm.. those are interesting little things.
i wouldnt mind getting some. seems like its a better way to go than stupid neon tubes.
Old Feb 27, 2005
Those are $15 and the first four are separated by 1 foot of wire, then alot inbetween, then the other four. So you can easily wire it in with four on each side and hide some of em if you don't want it too bright.
Readypro
May 2, 2015 12:23 AM
kanin247
Bolt-on Engine Performance
Apr 25, 2015 05:44 AM
thesushiboy
Apr 12, 2015 02:54 AM
Sarsura507
Feb 5, 2008 09:54 AM
civicPesek
Nov 7, 2001 11:33 PM
