engine noise and fuzz/static
Old Feb 23, 2005
frenchis's Avatar
frenchis is an unknown quantity at this point
I have engine whine noise in my standard, and it has a bad fuzzz static to it tooo and the power cable is runnin down a different side, the rca;s are runnin by the speaker wire mmm could that be it maybe not, but ive tried filters and other things and still no luck maybe the static gets a lil quieter but nothin great !! anyone any ideas thxx!!
Old Feb 23, 2005
PopcornPlaya's Avatar
Electric Boogaloo...
Try this, wrap the wires in some wire loom and run them down the passenger side. Insulate them the best you can (gotta be careful of semantics around here, there are grammar ****'s hawking the ice forums, because we all know spelling effects performance right? I digress...) and run them. The passenger side has the least moving parts is why I suggest there. I'd run the power, and remote down the driver's side, and speaker wire down the center (so it gievs you an equal distance to driver and passenger side). You can run them any way you want, just keep the RCA's seperate from everything else. If that still doesn't help, you might want to check into the qualityof the wire and step up to a better quality/grade.
Old Feb 23, 2005
coop's Avatar
coop is a jewel in the roughcoop is a jewel in the roughcoop is a jewel in the rough
does the buzzing change in pitch as you accelerate or does it stay constant?
Old Feb 23, 2005
frenchis's Avatar
yes it does change as i go faster and even if i push the button to make the windows go up or turn the head lites on i also have this converter for the indiglo dials i got for my dash and theres another static buzzin noise also so theres 2 problems
Old Feb 23, 2005
coop's Avatar
you have alternator whine. what brand of amps are you running? what filters did you try?
Old Feb 23, 2005
frenchis's Avatar
i have a 5 channel kenwood amp and not sure about wut filters i tried, but no good!!
Old Feb 23, 2005
coop's Avatar
I had this problem alot using lower quality amps. Radio shack makes a ground loop isolater that you install between the head unit and amplifier, I'd assume you'd need two to isolate your fronts and rears. Filters are under $20 each. Another factor may be the RCA wiring - cheaper wires don't have as much shielding and will conduct interference more.
The filters do affect your overall sound as I belive they work by eliminating frequencies from the sound spectrum that carry interference - but I didn't notice that much of a difference - audiophiles here will poo poo them.
The more expensive solution is to upgrade the amp....Alpine is VERY good at handling noise reduction.
Old Feb 23, 2005
coop's Avatar
further note - I'll NEVER recommend much from radio shack except these filters and their rechargable batteries....most anything else I've bought from them has turned out SHODDY.
Old Feb 23, 2005
frenchis's Avatar
Hey my amp cost 1200 dollars not that i paid that but its brand new why would it be crap???? and its soo custom that i dont feel like takin it all apart, only what i need to to fix the noise problem mmm so nothin can be done to the alternator or somewhere
Old Feb 23, 2005
coop's Avatar
I didn't know what brand of amp and model number - no insult intended. My experience with alternator whine is that some amps filter better than others.
Old Feb 23, 2005
frenchis's Avatar
Ya its all good, ya its the top model prety much, but it could be the problem, its jus pissin me off, we have tryed so many things even the guy that installed it cant figure it out!!! frak!! i wonder if there is a filter switch somwhere on the amp mmm, its just so hard to get at, cause of the way its in there but thx for ur input any other would be great thx
Old Mar 17, 2005
frenchis's Avatar
ttttt
Old Mar 17, 2005
ex_03's Avatar
Godlike member
ex_03 is on a distinguished road
Are you using twistedpair rca's?
Old Mar 17, 2005
catalin's Avatar
catalin is an unknown quantity at this point
Rick don't be mean, you know I can figure it out... I just don't have the fracking time without getting crapped on.
The one thing that you didn't try is the rca's rounted on the outside of the car. I know you're waiting for some and I will attempt to run out on my lunch break and get some. BUT I will most likely have them for you on Monday when I don't have to deal with any **** from my bastard employers!.... Or you could always drive to Richmond for me..
Old Mar 18, 2005
frenchis's Avatar
hahahah rick , ya sorry, jus lookin for opiinions !!!
Old Mar 23, 2005
frenchis's Avatar
whohooooo this whole problem is fixed thx to my great installer rick, new rcas did the trick cured both issues, now if anyone needs any installs let me know!! and i can send u in the right direction!! im really happy with all the work i have recieved!!
Old Mar 23, 2005
ex_03's Avatar
Godlike member
knew it was the rca's.
bokogabe
May 21, 2015 09:27 PM
CurryBomb
May 8, 2015 10:16 AM
smmahan
Apr 15, 2015 08:17 PM
silvervtec01
Dec 9, 2001 08:50 PM
TAZZ
Dec 5, 2001 09:35 PM
