RCA Little wire
Old Dec 31, 2001
Juancho007's Avatar
Juancho007 is an unknown quantity at this point
RCA Little wire
Hey what is the purpose of that little wire that comes with the rca cables??
Old Dec 31, 2001
Swifty's Avatar
From: Ricemond B.C. Canada, British Columbia, Canada
Swifty is an unknown quantity at this point
The little wire is to run the Remote turn on lead from your HU to your amp
Old Dec 31, 2001
LJ's Avatar
LJ
Fernando The Donkey Lover
LJ is an unknown quantity at this point
The remote turn on is a continuous 12 volt power signal that keeps your amp turned on
Old Dec 31, 2001
Swifty's Avatar
<< The remote turn on is a continuous 12 volt power signal that keeps your amp turned on >>
actually the remote turn on lead is a switched 12v+ signal that turns on when the HU is turned on and off when the HU is off...this in turn...turns the amp on and off accordingly
Old Dec 31, 2001
tsunamisplash's Avatar
tsunamisplash is an unknown quantity at this point
the constant to the amp is the big red gauge...
the ground is the big gauge black or brown cable....
haha.. it's like amp kit for dummies!
Old Jan 3, 2002
Juancho007's Avatar
No, you dont understand, its not a separate little wire, it comes as part of the rcas, in between the red and black wires of the rca cable.
Old Jan 3, 2002
Ed's Avatar
Ed
Yeah, that's what they are saying. basically with the two RCAs, there is another little wire. the little wire connects from the HU to the amp, which is the exact same as where teh RCAs are going. it makes it neater and all. Just connect it to the amp turn on on the HU and then to the AMP's power switch connection.
-Ed
Old Jan 3, 2002
LJ's Avatar
LJ
that is what i meant, but, when the cd player is on, it is a continuous power signal that keeps your amp on, and when the power is off, there is no more 12 volt signal
Old Jan 4, 2002
Swifty's Avatar
<< No, you dont understand, its not a separate little wire, it comes as part of the rcas, in between the red and black wires of the rca cable. >>
Trust us this is for the amplifier Remote turn on lead
Old Jan 4, 2002
Juancho007's Avatar
ok ill trust you, but then, what is the purpose of the other little wire that comes separate from the rcas that i thought was the remote?
Old Jan 4, 2002
VNlilMAN's Avatar
The Standard One
i'm guessing you got monster cables... it's supposed to get rid of the [badd] noise more or something(read the papers that came with it)... all you do is ground it...
Old Jan 4, 2002
Juancho007's Avatar
ok, that;s probably it
Old Jan 7, 2002
ThrashN's Avatar
ThrashN is an unknown quantity at this point
Do not use that wire for the remote wire.
Remember you want to run all power wires away from sound wires (speaker wires, rca's)
Old Jan 20, 2002
Slammed2k1's Avatar
Slammed2k1 is an unknown quantity at this point
Everybody uses it for the remote turn on but that is not what it is for. It is for grounding your amp to your headunit chassis to prevent noise from a "Ground Loop." Some amps have a separate ground on them for this, Kenwood excelons for example.
Chris
Old Jan 20, 2002
Juancho007's Avatar
Ok, so do i ground the hu to that second ground that the excelons have using that little wire?
SimpleUser
Apr 24, 2021 02:54 AM
Kevinsisco
Aug 31, 2015 12:04 AM
sch2cm
Jul 21, 2015 09:58 PM
CivicsClass101
Jul 9, 2015 11:14 AM
robbie374
Jul 7, 2015 02:56 AM
