bass issues
Old Feb 7, 2005
OFIVELX's Avatar
OFIVELX is an unknown quantity at this point
bass issues
hey guys noob here looking for some help, i havent had a car in a while used to have an expedition, traded it in for my new civic 4dr just put in two 12'' w6's, now my problem is that im happy with the bass when i have my seats down, but when there up all i here is rattling like crazy, do you guys experience this too? Or is there something you can do let the air flow through the front? Thanks in advance
Old Feb 7, 2005
ciVictoria's Avatar
Well if your hearing too much rattling I think you should buy some dynamat you can get it on e-bay for a good price. But from what I've seen it is alot of work to lay down and to cut and piece everything up. They also have the spray i'm not sure if that works though.
Old Feb 7, 2005
PopcornPlaya's Avatar
Electric Boogaloo...
First and foremost, read the sound deadening DIY. Mat deadener will do absouloutely nothing for you unless you do a few steps prior to that, such as foaming the trunk lid, foaming everywhere between gaps b/t pieces of metal pretty much. Simply matting will only trap the rattles in. There are a lot of other things that can be done which are covered in the deadening DIY stickied at the top.
Old Feb 7, 2005
4Saris's Avatar
4Saris is an unknown quantity at this point
Everyone's civic that I've sat in, rattles. Moreso on the outside, but the plastic trim piece in the back in the likely culprit. There are several threads on some cheap alternatives to fix it. I actually put in carpet pad between the metal and trim. Ghetto, but it worked.
By the way, try searching because although most are very helpful, some of these guys aren't too understanding why you can't be on the board 24/7 and read every thread.
Old Feb 7, 2005
"You talkin 'bout me?" I was mainly telling him that this issue has been covered many, many, many, many, many, many, many times before. Some searching, or simply reading the DIY at the top gives more answers than what will be given. Check your license plate too, and move the trunk latch as well, btw.
Old Feb 7, 2005
J187's Avatar
J187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of light
Reading the DIY will also give tons more info than we are giving here.
Old Feb 7, 2005
OFIVELX's Avatar
thanks guys, i did read the DIY but it just that i used to have an accord with the same subs and didnt remember it being this bad, but ill have to try some of your suggestions.
Old Feb 7, 2005
Our cars are notoriously bad for rattle issues. Don't ask why, maybe honda is working in conjunction with the manufacturers of deadeners because they know that civics are the most budget friendly tuner platform.
Old Feb 7, 2005
Bires's Avatar
Bires is an unknown quantity at this point
Originally Posted by PopcornPlaya
Our cars are notoriously bad for rattle issues. Don't ask why...
Because civics are economy cars. If they made them with the same standards of quality as accords, they would have to charge more. FYI: I drove a 04 Sentra SpecV previously, and they suffered much worse in the rattle/road noise/wind noise area.
The biggest problem is people putting giant subs in their trunks, crossing them around 60Hz, and wanting to feel base, without their cars feeling the bass.
I'll be dropping some Raammat in my car this weekend, in addition to the berberesqe currently under the carpet, and weather stripping on the trunk, but mostly because I want to drive the highway in peace.
Old Feb 8, 2005
fasssstjapbike's Avatar
fasssstjapbike is an unknown quantity at this point
Well we definetly know they are not working with ANY speaker manufacturers b/c of the PITA it is to change any speaker in our car.
Old Feb 8, 2005
J187's Avatar
The Pontiac bonneville and firebird are not economy cars, yet they rattle 10 times more than Civics. It's a factor that Civics are economy cars but its not an explaination. Sealing the friction zones when designing the car would have only made the price go up by about 50 bucks. It's just the design.
ej8
Apr 13, 2015 06:36 PM
mohawkboom
32
Oct 9, 2006 02:49 PM
NeonNights
Feb 20, 2002 07:54 AM
wishihadavtec
Feb 3, 2002 09:17 PM
edp22
Jan 27, 2002 02:51 PM
