active and passive crossovers
Old Jan 28, 2005
tripledoublegs's Avatar
Euro-Spec
How big is the difference between an active crossover and a passive crossover? I am asking you because I want to upgrade from my 9833 HU amplifier to a 2 channel. As some of you may know, the Alpine 9833-9835 has a 3 way switch which basically allows me to run active crossovers on my front components. I want to go ahead and get a 2 channel, but that would mean I have to use the crossovers that came w/ the Component Speakers. I was just wondering if I'll be able to notice any difference between the 2 setups. Thanks for your help.
Old Jan 28, 2005
thoughthard's Avatar
thoughthard is an unknown quantity at this point
As far as I can tell, you will still have to use the crossovers that came with the components. It splits the signal between the tweeters and the mid/woofer. The active crossover will just limit the signal frequency that goes to the component set.
Old Jan 29, 2005
J187's Avatar
J187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of light
To keep this brief
Active crossovers
Could have adj options
Can set xover points to whatever
Don't cause any use-loss
Raise noise floor a little
Require a channel for each freq range
costly
Passive
Inexpensive
Not powered device, no noise floor raise
one channel split
cheap and easy
Personally, I never like to have any sound control done at the HU level. I defeat all xovers, eqs, processors etc from my HUs.
Old Jan 31, 2005
darklegacy540's Avatar
darklegacy540 is on a distinguished road
^whew I'm glad he covered that one.. When I first saw the subject of this post, I was thinking, 'not another xover thread....'
IMO, I believe you have a lot better frequency control with an active xover, however it is more expensive considering you need to buy at least two.. one for each channel.. however, I also believe that troubleshooting any problems you may have in the future, is easier. Also, with passive xovers, there is "use loss" as J1872.. with it varying on what db/octave setting you have it set to. Just some food for thought
Old Jan 31, 2005
J187's Avatar
Yeah Dark, I thought the same thing at first but Then I thought, either that or another "c'mon someone help me. I know someone knows the answer" thread. LOL.
JK happy to help Triple.
Old Jan 31, 2005
kickercivic1's Avatar
kickercivic1 is an unknown quantity at this point
any good brand you guys like in active?
Old Jan 31, 2005
Check out any made by the Mitek Corp.. otherwise Alpine makes some good ones as well.
J187, LOL those threads crack me up sometimes.. ehh amateurs I tell ya ha
Old Jan 31, 2005
I don't know why the hell I typed "JL1872" in the post up there.. ha my bad.. I just noticed.
Old Jan 31, 2005
Euro-Spec
ok, thanks for all your help.
Old Jan 31, 2005
coop's Avatar
coop is a jewel in the roughcoop is a jewel in the roughcoop is a jewel in the rough
with cheaper components, I've found active crossovers much more useful in helping hide limitations of lower quality speakers - I had crappy *** Pioneer 6.5's in my Neon and they would distort below a certain frequency range with certain types of music. I found it handy to be able to fine tune it with the turn of a ****. That said, they do raise the noise floor - I ran a crappy *** Pyramid (don't laugh too hard) a few vehicles ago and it was terrible.
Old Jan 31, 2005
Pyramid? hahahahahahahahahaa j/k I only did that because you said not to laugh Hey we all go through our "ghetto" stages in our life.. it happens
Old Feb 1, 2005
coop's Avatar
yes we do - and that's where you eventually learn that you get what you pay for. But when you are on a budget corners get cut....
Old Feb 1, 2005
When I used to be on a budget, I just saved longer lol
What 6.5"s are you running now?
Old Feb 1, 2005
coop's Avatar
Boston Acoustics 6.5 Pro comps
Old Feb 1, 2005
Those are pretty sweet. Did you ever think about getting the Boston Acoustics Z Series?
My gf used to have the Pro Comps in her old car but she sold the car with them and I got her a set of JL Audio XRs from my shop in her new car.. I think both of them sound ungodly clean.
Old Feb 1, 2005
coop's Avatar
The Z series were almost double what I paid - I had a good amount of money to spend but not just on front comps. I was buying a deck, fronts, and rears for the 'vic. I might consider it next purchase...
I like their power handling and they do NOT flinch
Old Feb 1, 2005
The only thing I don't like about the Z series is yeah, they're around $900 I think or so.. but the xovers for them are HUGE! I guess I'm a fan of smaller xovers.. easier to mount, keeps a cleaner look IMO
Old Feb 1, 2005
coop's Avatar
didn't even think about the crossover size (and I thought the Pros were big!) - I had to get help mounting them as honda leaves you nothing but a round cutout once you gut the stocks, and I didn't have the tools nor raw materials to do the custom mod needed.
Old Feb 1, 2005
Euro-Spec
where do you guys put your crossovers?
Old Feb 1, 2005
coop's Avatar
inside the front doors
Old Feb 1, 2005
in the trunk.
Old Feb 1, 2005
MegaHurtz's Avatar
under the dash
Old Feb 1, 2005
J187's Avatar
The pro series Xovers were like two laptop computers. But the speakers sounded beautiful. As soon as you knock the tweets down AFAP. I used to have 6.5.3s in my car before last. 2 sets up front actually, and it was awesome.
Old Feb 1, 2005
I have mine mounted in the trunk as well. Has anyone even see the Z series crossovers besides me?
Old Feb 2, 2005
Euro-Spec
do any of you guys mind posting a couple pictures of the xovers in the trunk? I'm not sure where to put mine, maybe behind the hu somewhere...
blward6
Sep 16, 2015 05:32 PM
18
Aug 17, 2015 08:02 AM
