xbox placement
Old Jan 15, 2005
nunzio42's Avatar
nunzio42 is an unknown quantity at this point
xbox placement
aight so i have search and found the ps2 placement threads, but lets be realistic, ps2's are a little easier to place than an xbox. I want to place my mod'd xbox somewhere in my car, thinking about trunk or behind my driver seat (no one sits there) or somewhere else, someone PLEASE HELP........the only thing about the trunk is that rca cable cost a lot to run and i would need a lot of it. I am balling on a budget since i just got the screen and mod'd my xbox within the past 2 mths.
ohh yah and as for those of u with an xbox get it mod'd it is sooooooo pimp. you can do sooo much with this machine it is amazing!
Old Jan 15, 2005
Ed's Avatar
Ed
I'd go for the wheel well, If you slide your spare up, you should be able to fit it between the spare tire and the rear wall, all under the stock floor. Although, the way the CD tray comes out, it would be somewhat difficult to get to, but if it's all modded, you probably hardly need to open it to put a CD in.
Another place would be possibly, i'm not sure about this one, but in the trunk, on one of the sides, on the left or right, between the metal brace and the outer metal. You could have the tray stick out.
RCA cables aren't too expensive, if you can, get some cable and make your own, or get a lower end set of car audio RCAs, I got a set from hhgregg for really cheap, if i remember correctly, under $15 for a pair. If you need, measure it out and I can build you a set of RCA cables.
Old Jan 15, 2005
SiG's Avatar
SiG
Hey man
I dunno if you came across my thread as to where to place a ps2
I would put it in the trunk, or use the idea M3RKR33 found, whichever works
http://caraudiomag.com/technical/0305cae_swap/
Old Jan 15, 2005
nunzio42's Avatar
hey sig thanks for the article, they have a great place to place the invertor, i will def use that, as for the placement of the modual i am not sure xbox is too thick, ed thats a good idea......i will have to see about placing it on the floor in the trunk where the spare is, if not i think i may place it under my seat (drivers side) and just run the wires there.
Old Jan 15, 2005
Ed's Avatar
Ed
It might be easier under the seat [does it fit height wise?], especially for swapping out discs. How about under the passenger seat? I want to think there's more room under there.
Edit:
There should be enough room, I fit this lil 8" sub in there:
Old Jan 15, 2005
Ed's Avatar
Ed
The dimensions of that box are:
11"x5.5"x16.5"
The dimensions of the Xbox are:
11.4"x3.42"x11.4"
I really think it'll fit, when you try, make sure to unscrew the spare, and re-secure it using one of the lugholes, gives you another 3 or so inches.
I have my amplifier in there right now, and there is plenty of space to put a thick later of Foam under it, to protect the unit.
Ed
Old Jan 15, 2005
SiG's Avatar
SiG
No problem man
Old Jan 15, 2005
usafcushman's Avatar
7thGen's Loudest Civic...4,000 watts and climbing...
usafcushman is on a distinguished road
mine's going right here:
a little 'glass and alot of bracing, but it should look good...
Old Jan 16, 2005
nunzio42's Avatar
right now the xbox is under the driver seat, but, using a dvd remote the box needs to be relocated to either the passenger side bottom, or somewhere else? under the glove box may be nest which would not be too bad, i have have to figure out a way to make sure that i can remove it pretty easily. where do u find the metal brackets that are used to hold the xbox up? I may make a shelf for it and then mount it like that so i can slide it in and out.
where can i ger the metal strips? also can i remove the black thing under the glove box? it is like a black plastic thing that i am assuming is covering wires
Old Jan 16, 2005
yep, no screws or anything, just snaps off...
Old Jan 16, 2005
nunzio42's Avatar
true, so snap it off and then find some metal to tap into? what type of screws u gonna use......and do u know where to get those strips of metal?
Old Jan 16, 2005
sweetcivic03's Avatar
sweetcivic03 is an unknown quantity at this point
remove that ait bag and build a custom motorize enclosor for ur x-box
Old Jan 16, 2005
nunzio42's Avatar
sounds like a little much work for me i really like the idea of mounting it how they have it in the car audio magazine, and then dressing it up with a cover so it is harder to see. I just need someone to tell me where i can find the metal brace piece, bendable metal strips.....i am not sure what they are called but thats what i need!
Old Jan 16, 2005
that would definitely be sick, but S.A. drivers suck a$$, so i/m going to keep the air bags for now...
Old Jan 16, 2005
nunzio42's Avatar
usafcushman, do u know where to find the metal brackets?
ZoSoIV
Sep 17, 2015 07:17 PM
Strycker
Aug 18, 2015 02:25 PM
FlippedOut
Apr 20, 2003 09:05 PM
SLeePeR012
Mar 21, 2003 12:04 PM
AntiLoop
Mar 4, 2003 12:34 AM
