Wire through firewall
Old Jan 10, 2005
FiZZ's Avatar
FiZZ is an unknown quantity at this point
Where is the best place to run a power wire through the firewall of a 2002 civic? I saw a hole where a blue wire is already passing through on the drivers side, and a I saw a grommet on the passenger side behind the glove box that has a thick harness passing through it. Should I use one of these, or is there another grommet somewhere that doesnt already have wires passing through it?
Old Jan 10, 2005
Ed's Avatar
Ed
That grommet in the passenger's footwell is a very common place to shove the power wire through GO for it
Old Jan 10, 2005
custom2k1's Avatar
custom2k1 is an unknown quantity at this point
Depending on the size of the wire you may just want to drill your own hole low in the passenger firewall and pop a grommet in. Plus it looks much better.
Old Jan 13, 2005
sweetcivic03's Avatar
sweetcivic03 is an unknown quantity at this point
there is a blue tube going thru the firewall on the driverside.....pop out that gromet and pass ur wire thru there
SimpleUser
Apr 24, 2021 02:54 AM
Kevinsisco
Aug 31, 2015 12:04 AM
sch2cm
Jul 21, 2015 09:58 PM
CivicsClass101
Jul 9, 2015 11:14 AM
robbie374
Jul 7, 2015 02:56 AM
