Can I Put A Flipdown Scree With A Sunroof?
Old Jan 2, 2005
IrockCivics's Avatar
Hey guys, I wannit to know if I can put a flipdown tv screen in my civic even though I got a sunroof? and also whats a good size? If I can put one I wannit to get a 8inch, what do you guys think? Thanks.
Old Jan 3, 2005
ExZaCc's Avatar
Look what i did..
ExZaCc has a spectacular aura aboutExZaCc has a spectacular aura about
i have a 10.5 flipdown in my sedan... and i have a sunroof.. the hardest part to installing it is to make sure you sont **** up the sunroof cover with your screws and stuff.. hit me up on aim i you need help..
Old Jan 3, 2005
AlpineCivic's Avatar
Yes you can but then your relying on the headliner to take the weight of the screen, and it may vibrate and move because its not mounted to something solid.
Old Jan 3, 2005
Thanks for the help guys..... exzacc did you installed it yourself? If not how did you paid to get it installed? and one more question like AlpineCivic said does it vibrate or moves alot and how do you like it?
AlpineCivic will it still vibrate and move if I get it professionaly installed and is a 8inch to heavy?
If the flipdown monitor could'nt work I was thinking of getting a goose neck and mounting it between my rear seats like behind the cupholder in the floor do you that will work? or what would be better? Thank You again.
Old Jan 3, 2005
WhiteRabbit's Avatar
I dont know what kind of metal framing is under the headliner in a civic with a moon roof.
but most SUV's (all of the ones ive worked on, anyways) have metal framing between the moonroof and the headliner. even if its just a small bar.
you can screw a piece of quarter inch board to that bar using small metal screws, then replace the headliner and mount yoru flipdown to that metal.
I cant imagine a headliner able to handle the wear and tear from use of any flipdown, be it 6 inches or 16 inches in size. I suppose it has been done before, though.
when you pull your headliner, check for metal framing. if it were my own car, and I saw some frame, I would do it. If there was nothing between the glass and the headliner, id put the screens in the headrest or seek other alternate forms of TV
Old Jan 3, 2005
ExZaCc's Avatar
Look what i did..
yes i did instal it myself. and i mounted it to the subframe support under the headliner... DO NOT MOUNT TO HEADLINER ALONE!!! it wont hold-up to daily driving.. hit me up on AIM if you need help with the install.. i will get pics up as soon as i can of how i did it..
Wild Cranker
427
Jan 28, 2016 06:49 PM
MN-02-CivicEx
Jun 13, 2015 08:32 AM
Optimus34
May 25, 2015 11:52 PM
TonoAlpha
Apr 30, 2015 04:21 AM
Jandree22
Dec 13, 2001 03:23 PM
