remote starter
Old Dec 23, 2004
herroherror's Avatar
herroherror is an unknown quantity at this point
remote starter
I just bought an Audiovox Prestige remote starter with keyless entry. Does anyone know where I can find the wires for the power locks?
And do you know how I can connect the hood pin wire to the inside of the car? Someone mentioned I can do it through the side mirrors??
And one last thing.. the instructions say I need to tap into the ignition, ignition2, and ignition 3 wires. the wiring chart in the DIY (http://www.7thgencivic.com/forums/sh...d.php?t=153833) only shows one ignition wire. Do you know where i should connect the ignition2 and 3 wires?
Old Dec 23, 2004
vipergtsr's Avatar
vipergtsr should not be trustedvipergtsr should not be trustedvipergtsr should not be trustedvipergtsr should not be trusted
I got my power lock wires in the factory alarm harness. You can find the door trigger, trunk trigger, parking lights, and locks all in the factory alarm harness. It is on the left side of the stearing column. Pretty high up in the dash. It is normaly taped to itself if it has never been used. This is on ex models for sure I can't comment on LX or DX.
Old Dec 23, 2004
againifall's Avatar
Go Team Venture!
againifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of light
http://www.handa-accessories.com/civelec01.html
the keyless and alarm things have great PDF files that show you where most of that stuff is
Old Dec 25, 2004
2k2civic's Avatar
I would assume you can just leave them disconnected. According to my source, there is only one ignition wire for our cars...the second and third ignition wires are marked N/A. Try it with just the one hooked up and let us know if it works.
Old Dec 25, 2004
2k2civic's Avatar
Oh, and as far as the LX model goes...my 02 LX does have the harness also on the left of the steering column. That's where I went for door triggers.
Old Dec 26, 2004
profuse007's Avatar
Senior Member
profuse007 is an unknown quantity at this point
| DOOR TRIGGER|*2 |- |factory alarm plug *1 |
*1 The factory alarm plug is a green plug above the drivers kick panel. *2 The drivers door trigger is green, front passenger door trigger is lt. green/red, and the rear door trigger is green/white. use diode to isolate if use at this location.
| IGNITION|black/yellow |+ |ignition harness |
| ACCESSORY|black/red |+ |ignition harness |
| SECOND ACCESSORY|white/red |+ |ignition harness |
plug the rest of the ignition 2,3 into each acc.
| POWER LOCK|white/blue |- |gray plug above drivers kick|
| POWER UNLOCK|white/green |- |gray plug above drivers kick|
for LX, the two pin harness is taped to a split loom, (if i remember correctly).
555I works great on this vehicle.
Old Jan 13, 2005
sweetcivic03's Avatar
sweetcivic03 is an unknown quantity at this point
there is only one iginition on that car.....
Old Jan 14, 2005
profuse007's Avatar
Senior Member
yes, the diagram doesnt lie. one ign and two acc.
SammySC
121
Apr 7, 2017 07:43 PM
Nalmonte
Sep 28, 2015 01:10 PM
Skunkone
Sep 24, 2015 04:38 PM
meicalnissyen
Sep 22, 2015 06:20 PM
azuraT
Sep 8, 2015 02:53 PM
