I did the trunk rattle DIY and NOW....
Old Nov 18, 2004
manthatguysfast's Avatar
How many pots have you smoken?
manthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of light
Hey guys
I did the DIY trunk rattle by unscrewing the rubber bump stoppers a tad and lowering the trunk latch so its held down tighter ..... but now the trunk is just a bit higher in the back (by the rear window) so there is a gap and leaves and such can fall in. is this normal??
I know to fix it all I have to do is screw in the rubber bump stop things again so the back side of the trunk goes down a bit - but, wont this may make the trunk rattle again?
anybody have this problem with the DIY? what have you guys done to fix it?
Old Nov 18, 2004
darklegacy540's Avatar
darklegacy540 is on a distinguished road
I never did the DIY, I got dynamat instead.
Old Nov 18, 2004
PCaly2112's Avatar
PCaly2112 is an unknown quantity at this point
I did the bumper part but didn't mess with the trunk latch at all, and i added some dynamat extreme, no problems at all
Old Nov 18, 2004
TeLLy's Avatar
Yes, it's an Acura EL
I lowered the trunk latch, partially unscrewed the rubber bumpers, and also slathered on some B-Quiet Xtreme on the inside of my trunk lid. Still rattles where the taillights are bolted on, but there's no gap at all, it looks like stock, save for the Ferio lights. I do have to push down a little harder to shut it though.
Old Nov 18, 2004
john_817's Avatar
john_817 is an unknown quantity at this point
theres no problems with my trunk wen i did the rubber stoppers but there was still rattle on the trunk. i finally moved the latch down as far as it could go to be able to close the trunk and now it has reduced the trunk rattle by a lot. I think i could use some dynamat to reduce rattle even more.
Crazygrlinak
Oct 8, 2015 05:06 PM
rovafa2002
Sep 28, 2015 06:57 PM
Sep 27, 2015 11:33 AM
General DIY
Sep 25, 2015 08:02 PM
speedlever
Sep 24, 2015 07:18 PM
