HELP cig lighter wiring!
Old Nov 17, 2004
Trying to wire a neon to my amp and it came with a cig lighter plug. I need to know which is negative, the sides OR the top round part on the cig lighter Thanks!!
Old Nov 17, 2004
vicn77's Avatar
vicn77 is an unknown quantity at this point
it's usually the sides is negative...top part is positive
Old Nov 17, 2004
Thanks!!
Old Nov 18, 2004
vicn77's Avatar
n/p...glad to help
Old Nov 18, 2004
joe6680's Avatar
joe6680 will become famous soon enoughjoe6680 will become famous soon enough
Makes sense. Think about the part that gets hot, typically people call the positive the hot lead.
Old Nov 18, 2004
bakuretsu's Avatar
bakuretsu is an unknown quantity at this point
Or think about it this way... If the sides were positive, you could very easily electrocute yourself by accidentally touching the edges of the socket if your other hand was touching ground. For example, your window frame.
THAT would be smart.
Hence, the "hot" lead is buried. You'd have to stick your whole finger in there.
Old Nov 19, 2004
joe6680's Avatar
^^^Uhm I dont think so...That'd be like touching the positive and negative battery terminals at the same time. You dont get electrocuted then.
Old Nov 19, 2004
bakuretsu's Avatar
I would tend to disagree with you there, chief.
Old Nov 21, 2004
2slow2run's Avatar
wut time is it now
2slow2run is an unknown quantity at this point
u should find like a 9v battery n just try it always works for me
Old Sep 23, 2005
flyguy050's Avatar
flyguy050 is an unknown quantity at this point
Bust open the plug and you will see the two wires, one actually goes into the plug and the other is clamped or soldered onto the rim of the plug, the one that is soldered on the rim is the negative and the other is positive
Old Sep 25, 2005
05reverb's Avatar
05reverb is an unknown quantity at this point
You can't get electricuted with 12 volts, you need 24 volts or more to start feeling a sensation of shock. If you don't know anything about electricity, don't post wrong answers.
Old Sep 25, 2005
fyi, I touched the neon circuitboard and got shocked. Not enough to die but enough to feel it pretty good. And I can feel 9v battery too.
Old Sep 25, 2005
05reverb's Avatar
Neons have a tranformer to up the voltage, that's why you got shocked, they do not run on 12volts. As for the 9 volt battery, it only shocks you on your tongue because it's a wet location and more current passes through you, you do not get shocked by touching the 9 volt battery with your fingers.
Old Sep 25, 2005
MegaHurtz's Avatar
Because I'm stupid, I once accidentally grabbed one of the strobes in my trunk when it was turned on. **** I could almost see God.
But gearbox, the positive would be the lead that is closest to the middle of the socket. Ground is the outside, power is on the inside, which is the pin, so the power wire would be the one closest to the pin, ground closest to the outside
SimpleUser
Apr 24, 2021 02:54 AM
Dave1984
Jul 22, 2015 06:10 PM
sch2cm
Jul 21, 2015 09:58 PM
CivicsClass101
Jul 9, 2015 11:14 AM
robbie374
Jul 7, 2015 02:56 AM
