Headunit install in older cars?
Old Nov 17, 2004
Vinnie's Avatar
Vinnie should not be trustedVinnie should not be trustedVinnie should not be trustedVinnie should not be trusted
I was wondering if anyone could tell me how to do a headunit install for scratch. My friend has an old pontiac lik 68 or seomthin. Anyway how would we go about installin a head unit if there are no original wires to begin with?
Old Nov 17, 2004
grenloch101056's Avatar
grenloch101056 is an unknown quantity at this point
first find a constant 12 volt line, a line that shows 12 volts only when the ignition is switched on, and a ground wire. Then you need to take care of the speaker cables. Either run new wire or search around behind the dash for the original ones. you should have 11 cables once your done.
Old Nov 17, 2004
J187's Avatar
J187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of light
Some older cars have funky grounds, like through the antenna or something. You may need to run a new ground to the chassis. If he's not concerned about sound, some companys make shaft radios that go right into place in shaft mounts.
Old Nov 18, 2004
Vinnie's Avatar
so any suggestions as where i would find a good turn on lead? Otherwise i think we could run it straight to the battery with a fuse of course but also a cut off switch just in case the battery is drained...any other ideas and info would be helpful.. thanks!
Old Nov 20, 2004
Vinnie's Avatar
help? bump
Old Nov 20, 2004
Vinnie's Avatar
is this an acceptable application?
Old Nov 20, 2004
againifall's Avatar
Go Team Venture!
againifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of light
just go to WCC they will pimp yer ride!!!
hehehehehe
Old Nov 22, 2004
BassKadett's Avatar
BassKadett is a name known to allBassKadett is a name known to allBassKadett is a name known to allBassKadett is a name known to allBassKadett is a name known to allBassKadett is a name known to allBassKadett is a name known to all
When I installed cd players in my first car, 69 Dodge Dart, I ran the power wire to the dome light fuse and it never gave me any problems. Good luck man and don't destroy the car's dash just because you guys want to put a new deck in it. I did and I regret it...even though I don't own the car any more.
CarStuff
Dec 6, 2020 12:52 PM
Jon-Ohio
Jun 30, 2018 08:10 PM
usajags84
15
Aug 19, 2015 03:12 AM
nickfn
Nov 8, 2001 09:44 AM
2k1TypeR
Sep 25, 2001 09:25 AM
