PS2 remote turn-on?
Old Nov 8, 2004
blk03civic31's Avatar
blk03civic31 is an unknown quantity at this point
Lightbulb PS2 remote turn-on?
I wanted to know if it was possible to wire a ps2 to turn on with with either a switch. I have it in the trunk and every time i want to turn it on i need to go into the truck and push the reset button. Is something possible?
Old Nov 9, 2004
Ed's Avatar
Ed
I don't know anything about how a PS2 loads, but if the power switch is on, and there is power coming in, does it boot on it's own?
If not, and your questions is how to hit the 'reset' button from within the car, there are a few things you could do, you could find the contacts that are within the PS2 and extend them to the interior, using a switch or a relay.
If you just want to switch the power that is connected to the PS2, you could use a relay from up front to switch the power, you could even do it from the HU's remote turn on lead to trigger it.
Old Nov 9, 2004
I could extend the reset button but it is a ribbon and i dont know how to extend a ribbon.
Running the remote turn on wire from my headunit is a good idea, what is the polarization (+ or -) the remote turn on wire sends?
Old Nov 9, 2004
MegaHurtz's Avatar
+ 12v
Old Nov 9, 2004
lkm's Avatar
lkm
Super Member
lkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trusted
you guys need to go to walmart soon! you know they have that thingy that resets the console, ask them how they do it.
Old Nov 9, 2004
what are you talking about? what is at walmart, something i can buy or learn how ot hook up?
Old Nov 9, 2004
civic01vtec's Avatar
ummm..............are u from outer space ??????
Old Nov 9, 2004
No, how about you?
SammySC
121
Apr 7, 2017 07:43 PM
meicalnissyen
Sep 22, 2015 06:20 PM
Dsmak
Sep 10, 2015 08:30 PM
sbi
Sep 2, 2015 07:44 AM
jdrolltide
Sep 1, 2015 06:54 PM
