Anyone make a wall yet?
Old Nov 5, 2004
ohiojosh78's Avatar
ohiojosh78 can only hope to improve
I'm going to be making a wall behind the back seat of my vic because i'm having so much trouble making a box big enough and with good enough air flow into the cabin to play as loud as it should.It's a DD9917 as some of you know and I had it in my tiburon before but there was much more room and it was MUCH louder in that car than what i can get in my civic and i've tried 3 boxes so far and none of which are even close.
The wall will be following the slope of the rear seats and i will also be covering up the 6x9 holes so that there is no transfer of air from front to back. I was wondering if anyone else has done this. Or has anyone seen or have pics of this?
Old Nov 5, 2004
Rufus's Avatar
I thought Alex053 did. I have a false floor but no wall.
Old Nov 5, 2004
MegaHurtz's Avatar
I saw another pic with a setup like that as well a few days ago, but can't find it right now, if I find it I'll post it.
That setup got loud at dB Drag finals but personally I think it would be louder if you put both subs on the passenger side and the port on the driver side.
You sure that beast is even going to fit right there behind the back seat?
Old Nov 5, 2004
MegaHurtz's Avatar
w00t found it
Old Nov 5, 2004
MegaHurtz's Avatar
It's the same car in both pics, just a little different box
Old Nov 5, 2004
Rufus's Avatar
Nice HOMO port, but what are ya gonna do when port length equals 8 feet?
Old Nov 5, 2004
J187's Avatar
J187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of light
Did you say Box? that looks more like c^ck
Old Nov 5, 2004
alex053's Avatar
i did.
you are going to have a hard time finding enuff room for a 9917. you would be better off with a 15 using a bigger box.
took a week to get the 6 batteries, four amps, the box and subs in....45 minutes to rip it out.
got about 13 cubes before port displacement....i cant remember the dimensions...maybe 33x16...played at around 55-60hz and did a 156.7 first and only time out....unoffical..it was a work sound off event.
Old Nov 5, 2004
ohiojosh78's Avatar
Hey alex thanks but i meant a wall in the trunk not the whole back half. MHZ thats what i was looking for. Also yes the 9917 beast will fit. I used to have my box facing forward but it sounded like @ss because of the airflow back into the trunk around the edge of the box. Yea, facing the box rear or up is good. But i think teh MOST efficient way is to wall off the trunk.
Alex, as far as not using the beast. Well...not using a $1600 sub is a bit crazy But yea i'm gonna buy two 9512s soon for another install. Not sure if i wanna give my GF the 2 12s or the beast. hmmmmmm
Thanks for teh info all.
Old Nov 6, 2004
LudlamTheory's Avatar
i boogie for the raindrops
wall in the trunk has been done by two people, and im almost entirely sure of the process, and the performance of them since both people talked to me extensively about them.
from what i've seen, theyve both bested their setups with boxes in trunk.
also, from the trunk you can still get plenty of space
I have done 6.2ish cubic feet inside the trunk without touching the spare tire well. I'm sure including the tire well you could easily do 8 cubes, although the install will be such that the only way to get it out will be by sedtroying it, but hey, if youre really so into the hobby, its not that much money if you think about it
Old Nov 6, 2004
ohiojosh78's Avatar
my problem isnt entirely air space inside the box(but that is part of it). It's that since its an 18"(17.9) sub and it is so deep i do not have many options. I cant really mount it facing up or rearward because the speaker limits how small i can make the box in any one direction which in turn limits the size of the air flow passageways.
Right now my trunk is incredibly loud but not much of that is passing into the cabin. And i cant face the sub rear because of trunk clearance. Even if it did clear the trunk then I'd have NO space for airflow backinto the cabin. I'm thinkin my only option is to face sub forward and slant it so that i can get a little extra room for height.
Old Nov 6, 2004
Regularjoe's Avatar
Regularjoe is on a distinguished road
How about a downfiring box of some sort ...... then the driver movement coincides w/ the springs and shocks .... should shake the hell out of the car.
jordan1794
Jun 11, 2015 09:14 PM
Pudnite
May 9, 2015 07:51 PM
bobbyd
Dec 14, 2001 04:24 PM
rowdyb7
South
Dec 5, 2001 03:02 PM
aZnVoYCe
Bolt-on Engine Performance
Nov 4, 2001 10:18 AM
