port calculator
Old Nov 2, 2004
ohiojosh78's Avatar
ohiojosh78 can only hope to improve
port calculator
This port calculator doesnt take into consideration the volume of internal box space it takes up does it. I mean if you have a box of say 2 cubic feet and it says you need a port 12" long that has a opening of 12 square inches, you'd actually have to have a 3 cubic foot box right? becuase the port would take up a cube itself right? Or you could have a box of a certain size then calculate the port but then you'd have to make it an external port as not to take up box space correct?
Lud, you know for sure?
Old Nov 2, 2004
MegaHurtz's Avatar
I would think so but I will wait for Lud's scientificly proven answer
Old Nov 2, 2004
LudlamTheory's Avatar
i boogie for the raindrops
1 cubic foot = 1728 cubic inches...
but yes, the port itself displaces air, as does the wood used by the port, but 12 sq inches by 12 inches long would only be 144 cubic inches, less than .1 cubic feet. cubic feet = (l x w x h) / 1728.
so yes, you need to add it on manually, but it isnt hard. just do it on paper.
Old Nov 3, 2004
ohiojosh78's Avatar
lol you missed one yes 12 sq inches x 12 inches long = 144 but the first figure is SQ inches so you have to multiply that by 12 again. because 12 sq inches IS 12 x 12. I think you just accidentally read to fast.
But your answer is that port area is not accounted for?
Old Nov 3, 2004
no sir, 144 sq inches is 12 by 12...
12 sq inches is 3 x 4, or 6 x 2, or 8 x 1.5, ad infinitum
Old Nov 3, 2004
ohiojosh78's Avatar
oops lol you're right. i meant a square foot not 1/4" x 48". lol dammit you cold be wrong some time you know.
Old Nov 4, 2004
well, if i was, then i wouldnt be the moderator here, would i
Old Nov 5, 2004
alex053's Avatar
you forgot the that you have to take the outside dimensions of the port....dont forget to add the thickness of the wood we all know it will make a huge difference.
burnyd
ECU Fried
May 24, 2018 10:44 PM
99BoostedSi
Sep 7, 2015 04:49 PM
bsmiley
31
Sep 1, 2015 06:11 PM
cwisenbaker06
Aug 19, 2015 04:29 PM
user 84948
Air Conditioning
40
Jul 10, 2015 07:08 PM
