head unit complications
Old Oct 20, 2004
jmaz's Avatar
jmaz is an unknown quantity at this point
Does anyone have the kenwood kdc-x869 or kdc-x969. The eq controls are killing me. there are to many many features.if any one has this head unit and understands most of the eq features please let me know i have a whole bunch of questions
thanks
Old Oct 20, 2004
4Saris's Avatar
4Saris is an unknown quantity at this point
Just use the user function and set it to what you want. You can set your preference on the bass, middle, and treble.
Old Oct 20, 2004
J187's Avatar
J187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of light
I'm not big on EQ and X OVER settings in HUs. If I didn't buy amps with good crossovers, I'd buy a good crossover. I almost always defeat all the settings on my HU. Alpine has a nice feature called, Defeat. Where by setting that on, you can just eliminate any xovers or whatever from the HU.
Old Oct 20, 2004
jmaz's Avatar
yea i know the basics, but there all these functions on top of the basics
bass:
Bass center freq. Range: 60/70/80/100 or 150 hz
bass level: -8 -- +8
Bass Q factor: 1.00/1.25/1.50/2.00
Bass Extend: on/off
mid:
middle center freq. Range: .5/1.0/1.5/2.0 khz
Middle Level: -8 -- +8
Middle Q Factor: 1.0/2.0
treble:
Treble center freq. Range: 10.0/12.5/15.0/17.5 khz
Treble level: -8 -- +8
On top of that, there are these functions:
front high bass filter: Through/40/60/80/100/120/150/180/220hz
rear high pass filter: Through/40/60/80/100/120/150/180/220hz
non-fading low pass filter: 50/80/120/through hz
loudness
wow
trubass
focus
srs
volume offset: -8 -- +=0
non-fading level: -15 -- +15
non-fading phase: normal (0 degrees)/Reverse (180 degrees)
I have seen some very intelligent comments to tech. questions on this board.Someone must know what these mean!
Please help me out. thanks in advance
Old Oct 20, 2004
jmaz's Avatar
i have heard so many people on these forum speak about setting all eq functions from the head unit to o or off, but when i do that it just sounds like ****.
Old Oct 21, 2004
J187's Avatar
That means you've got some problems in your system somewhere, more than likely you don't have a properly set crossover. All you should NEED to get your sound to not be 'Shtty' is a well set xover, a good install and good equipment. If you are using EQ settings to fine tweak thats one thing, if you are using your EQ settings to mask bad sound, well thats like wearing extra cologne cause you forgot deodorant. . . Why don't you commit to getting it set right, start a thread and we'll all help you.
This is not to say that you SHOULDN"T use EQ settings on your HU, but you shouldn't NEED them.
Old Oct 21, 2004
jmaz's Avatar
Ok then i will start with this. Here is the equipment that i have:
Kenwood Kdc-x869 head unit
Mb quart 6.5 components pce-216 in doors with tweeter attached to the speaker
Boston acoustic 6X9 3 ways
Precision power 300/4 amp (interiors)
jbl 300.1 amp (subs)
2 10 infinity ref. in a custom made sealed box
As far as the crossover goes on the quarts, i have never done anything to them. i have left them on whatever the dealer set them at. To be honest i wouldn't know the first thing about messing with them.
well here is a start!
questions, comments are much appreciated
Old Oct 21, 2004
jmaz's Avatar
you know what i will just put this into a new thread
edp22
Jan 27, 2002 02:51 PM
oblivious9
Jan 25, 2002 10:28 PM
bobbyd
Jan 7, 2002 01:31 PM
Slow2k1Civic
Jan 1, 2002 06:51 PM
noodles01
Dec 28, 2001 09:07 AM
