2 or 4 ohm sub needed?
Old Oct 6, 2004
RSXtypeIvtec's Avatar
Su Mo
I have this amp: http://www.crutchfield.com/S-dMmM31c...p?i=500MRDM301
Alpine MRD-M301
Specs: 175 watts RMS x 1 at 4 ohms
350 watts RMS x 1 at 2 ohms
I want to get a dual voice coil sub; should i go with a 2ohm or 4ohm sub?
some people were telling me to get 4ohm cause it would be louder, but i dont understand why if the max rms is at 2 ohms...i thought a 2ohm sub would be better. Someone tell me which one is right?
Old Oct 6, 2004
alex053's Avatar
dual 4 ohm
Old Oct 6, 2004
Su Mo
why???
Old Oct 6, 2004
tbaleno's Avatar
tbaleno is an unknown quantity at this point
A dual 4 ohm voice coil sub can be wire to 8 ohms or 2 ohms, a dual 2 ohm can be wired to 1 ohm or 4 ohms. If your amp can't handle 1 ohm then you will have to wire a dual 2 ohm to 4 ohms which would give less out put than wiring a dual 4 ohm to 2 ohms. Make sense. I knew it would
Old Oct 6, 2004
Su Mo
i see now...thanks
Old Oct 7, 2004
J187's Avatar
J187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of light
Read that and you REALLY understand.
http://www.jlaudio.com/tutorials/wiring/index.html
Old Oct 7, 2004
shmik1's Avatar
^^^ Good link I always reference JL wiring tutorial..
11fa5
18
May 17, 2015 09:53 PM
Myredjonda
Apr 14, 2015 07:00 PM
2k2CivicEX
Nov 5, 2001 07:22 PM
mohawkboom
Nov 2, 2001 06:00 PM
