SRS Light won't go off
Old Oct 5, 2004
higgie's Avatar
higgie is an unknown quantity at this point
My battery died and I had it replaced. Since then, the SRS light won't go off. I have a 2001 civic LX and the dealer said he would charge $85 just to hook it up to the machine to see if anything is wrong. Is this normal when you swap batteries?
Old Oct 6, 2004
winnerpl's Avatar
winnerpl is an unknown quantity at this point
No it's not normal. Weird in fact. Maybe just your computer needs to be reset.
Old Oct 6, 2004
MegaHurtz's Avatar
Why did you replace your battery if it died? Batteries can be charged.
Old Oct 7, 2004
4Saris's Avatar
4Saris is an unknown quantity at this point
There is an SRS reset procedure that is really easy to do with a paperclip. Search for it and try it prior to dishing out $85. Try it 4 times at the minimum, it takes practice to get it.
Old Oct 7, 2004
J187's Avatar
J187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of light
http://www.7thgencivic.com/forums/sh...d.php?t=155251
Keep trying it works. Use a small paperclip
Blazz
May 25, 2015 10:56 PM
cukaracha
May 16, 2015 02:11 PM
bo_red
Transmission
May 3, 2015 09:14 PM
XtremelySpoiled
Dec 13, 2001 08:47 PM
SimDogg
Nov 27, 2001 04:20 PM
