LCD center console
LCD center console
I have a quick question for you all. I bought this: http://www.crutchfield.com/S-3LBLc30...&avf=N&search= to run my HKS CAMP unit (for shows and such I'll play DVD's) but the problem is I think I'm going to need a double din insert so it can be lined up. Since I really don't know that much about this kinad ish, can someoen take a look at the above link and recomend what I get. Since it's gonna replace the stock headunit, i saw a thing called like meta or something. Can you guys help me out. Thanks!
Brad
Brad
... =*( I hope someone can answer soon so I can buy what I need. The Screen will be here on Thursday
im not sure what you will exactly need but it will be something like this
http://www.crutchfield.com/S-etQLDnd...&avf=Y&search=
but thats for a single.
Yeah, I saw that, but if you look, the top opening is bigger than the bottom one. I need something where oth the openings are standard din size, and combined should be like 4inches tall. I would be suprised if they didnt make them, but all I can find on google are ones that are uneven sizes. I'm starting to get worried...
Check the flip-flop DIY which should be sticked on this forum. I believe it requires buying a double din sized kit and you can get the part # from there.
Good luck
Good luck
Hahahaha, I saw the part number, but I just wanted to know if anyone knew of a part that FOR SURE will work. With that part if you look, youll have to do almost as much vustom stuff, youll have to shave alot of it, i just wondered if anyone knew of something that I wouldent have to screw with
Electric Boogaloo...
They don't make one with a double din opening without the divider. It even tells you in the instructions provided in it that you can cut it out. There's no custom work required other than cutting the piece out. It takes maybe 20 seconds to do.
rman1900
21
Sep 10, 2018 04:52 PM
ricer_em2
May 11, 2016 08:09 PM
solarpunk70
Apr 12, 2016 11:43 AM
MichaelLW
Sep 14, 2015 07:15 AM
