would grounding help more if.........
Old Sep 8, 2004
mr_fobster's Avatar
i had a optima yellow top batt?(will be getting one soon from a friend in napa this weekend)? would i still feel some of those little gains people are talking about? or would i experience nothing with grounding and this batt?
Old Sep 8, 2004
MegaHurtz's Avatar
Changing your battery has nothing to do with your grounds, but I would still recommend the swap if you are running large amounts of audio.
Old Sep 8, 2004
Team Hi Voltage's Avatar
Team Hi Voltage is an unknown quantity at this point
Old Sep 8, 2004
mr_fobster's Avatar
ok since i would have the stock batt and the yellow top.....which one should i run for my system? the yellow top? or should i just run the yellow top for my primary and run the stock batt for my system?
Old Sep 8, 2004
MegaHurtz's Avatar
yellow top for your system
Old Sep 9, 2004
mr_fobster's Avatar
ok so if i am going to use the yellow top for my system, wont it need to be recharged like every now an then? i dont get it cuz i have heard about the battery in the car recharging its self with the alternator??? iono still a noob at this....and so how would the yellow top powering my system stay charged like the car batt? for that long?
Old Sep 9, 2004
MegaHurtz's Avatar
You hook it up with an isolator so that when the car is running they are both charging but when you turn the car off the isolator seperates the back battery from the rest of the car so only the yellow top will be running your system
Tedverseti
Apr 23, 2020 01:45 PM
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
Munzy
21
Oct 7, 2015 07:48 AM
Tedverseti
Sep 29, 2015 05:41 PM
260000milesgoal
Sep 25, 2015 07:41 PM
