Self-Install or Shop Install?
Old Aug 31, 2004
Zee's Avatar
Zee
Zee is an unknown quantity at this point
Question Self-Install or Shop Install?
I just received a new head unit for my car from my friend.
An: Aiwa CDC-Z127YUC
It's not the best but it'll do better than the stock system, I hope.
Now, what I'd like to know is, should I install it myself? I think I'll need a new harness because the power wire is very short (less than 1 inch) and some of the wires are in very bad condition. Are these hard to find?
Also, what tools will I need to self-install it?
OR
Would it just save me time and money to go to an audio shop and have them install it? Your input is greatly appreciated.
Zee
Old Aug 31, 2004
exclusive_vtec's Avatar
i think u should do it urself.. u will get more experience out of this more fun.. and u will feel much better about it when its done and done by ur self.. u will save money thats for sure.. and shouldnt be big of a problem so i say do it ur self over the weekend shouldnt take more than 1-2 hours enjoy
Old Aug 31, 2004
winnerpl's Avatar
winnerpl is an unknown quantity at this point
DIY!!!!! It's fun
Old Aug 31, 2004
coop's Avatar
coop is a jewel in the roughcoop is a jewel in the roughcoop is a jewel in the rough
which harness is in bad shape - the one supplied the AIWA deck or the harness that interconnects it to your car? If it's the AIWA harness - good luck. You'd probably have to contact them to get a replacement, which might not be easy or cheap....
Old Aug 31, 2004
evilone's Avatar
The Nightraid crew - Sensible Ownage
evilone is a jewel in the roughevilone is a jewel in the roughevilone is a jewel in the roughevilone is a jewel in the rough
Hell, just grab a soldering iron and lengthen the wires.......it's simple to do a DIY stereo install, if you pay shop prices for something like that, you're nuts. And if you really need help with it, just post your problem on here, somebody'll help ya out pretty quick.
Old Aug 31, 2004
Zee's Avatar
Zee
Thanks a lot guys. The harness which is in bad shape is the one that came with the Aiwa receiver. I saw them on eBay for like... $2-6. I'll probably install it myself.
The only thing that I'm concerned about is: the touching of certain wires which might cause sparks?
I'm pretty sure on how to wire the speakers but the other four:
Red -- To Power (ACC)
Yellow -- To Battery Direct (Back Up) Fuse 15A
Black -- To GND (Negative Ground)
Blue -- Relay Control; To Power Antenna/To Remote Control; Fuse 0.5A
What do these mean? And will the wires in my car match the colors of these wires? That would help a lot. I appreciate it guys.
Zee
Old Aug 31, 2004
shmik1's Avatar
http://www.installdr.com/Harnesses/HA-Wiring.pdf see if this helps any, Im not sure if its 100% current or not but it might help..
Old Aug 31, 2004
HondaSales's Avatar
HondaSales is a glorious beacon of lightHondaSales is a glorious beacon of lightHondaSales is a glorious beacon of lightHondaSales is a glorious beacon of lightHondaSales is a glorious beacon of light
i would leave the factory cd player in over the aiwa. but if you're gonna put it in, DIY.
Old Aug 31, 2004
Zee's Avatar
Zee
Pictures
Is the stock player better than the Aiwa?
[edit]
Here are pictures of the receiver and the harness. You can see the red one is extremely short.
Aiwa CDC-Z127YUC
Pictures 6 & 7
[/edit]
Zee
Old Aug 31, 2004
Mystic3030's Avatar
Yup, i'm an A$$hole.
Get a replacement AIWA harness on ebay or through an AIWA dealer. Then you need to get a Metra harness for your car. The wires are all color coded, so all you have to do is match them up. You will also need a dash kit, get this from crutchfield.com or a similar site, or a store. Tools required will be screwdrivers and a ratchet, wire crimpers, and but-connectors.
Honestly, I would leave your factory radio in too...AIWA is pretty low-end.
Old Aug 31, 2004
MegaHurtz's Avatar
If you have to put that deck in just DIY. We have more than enough info on the site here to help you out.
If you want to find my thread on how to remove the deck, do a search for <EDIT> and it will find my good DIY pic
159
Jul 5, 2015 09:54 PM
97-DX-Lover
Jun 14, 2015 06:07 PM
kanin247
Bolt-on Engine Performance
Apr 25, 2015 05:44 AM
aZnVoYCe
Dec 7, 2001 12:41 AM
aZnVoYCe
Nov 7, 2001 05:54 PM
