factory cd player or another unit?
Old Jun 28, 2004
higgie's Avatar
higgie is an unknown quantity at this point
I have a civic 2k1 coupe with the stock tape player and i want to be able to play cds. is the amount of work needed to install a factory cd player, say from www.handa-accessories.com, more or less than that needed to install a 3rd party unit like an Alpine or clarion from crutchfield?
Old Jun 28, 2004
LiKEaFeRiO's Avatar
Factory CD player is easier than wiring up a aftermarket one.
Factory is just plug and play I think.
Make sure you get a security code.
Old Jun 28, 2004
Ed's Avatar
Ed
If you decide to get a stock Cd player, don't get a retail one, just hit one off our forums here, there are always some available, fo a lot less i would imagine as well. LIke he said above, jsut be sure to get the security code.
Old Jun 29, 2004
Free2Rhyme26's Avatar
Diamond Member
Free2Rhyme26 is an unknown quantity at this point
personally i would go aftermarket. takes a lil bit mre work to install, but u can always have sum1 install it for u.
Old Aug 27, 2004
lewal's Avatar
lewal has a spectacular aura aboutlewal has a spectacular aura aboutlewal has a spectacular aura about
Higgie,
If you decide to buy an OEM cd player, let me know. I should have mine out of my car w/ security code by the weekend
Old Aug 27, 2004
Come on guys. Get a wire harness and the aftermarket deck plugs right in. It's the same amount of work to install it. The stock deck is horrible both for rms power and tuning. You'll be much happier with a different deck. You could even spend a couple hundred and get one that plays mp3 cds. But if you really want stock, I've seen em on here going for $30-50.
Old Aug 27, 2004
DrivenConcepts's Avatar
Don't Listen To What Anyone Says, It's Ok To Be Jealous
DrivenConcepts should not be trusted
yea actually they make "smart harnesses that factory harness plugs into and then plugss into another harness that plugs into the cd player. about the same time it takes to plug in a factory deck
Old Aug 27, 2004
brash's Avatar
brash is an unknown quantity at this point
The work involved in getting to the point where you can replace the HU is way more trouble than any work involved in plugging the HU in... I really wouldn't consider an aftermarket HU much harder to install than a factory one. Buy a harness and some of those screw cap connectors, and once you get the panel off (which you have to do no matter what), it is pretty damn easy to install an aftermarket deck.
Old Aug 28, 2004
Diamond Member
//Alpine <------*drool*
i'm gettin pioneer for my next deck
Old Aug 29, 2004
Amer786's Avatar
Senior Member
Amer786 is an unknown quantity at this point
i got the CDA 7998 ... MMMMMMMMM
Old Aug 29, 2004
Diamond Member
grrrr.........not fair
Old Aug 29, 2004
PopcornPlaya's Avatar
Electric Boogaloo...
Meh... save some money and get an aftermarket one. If you plan on upgrading your audio system, you'll eventually buy an aftermarket HU anyway, so save the hassle and money you'd spend on getting a stock hu now. You'll be plesantly suprised at what you can get an aftermarket hu. There's a DIY on here for installing a HU, it's step by step, follow it, and you'll have no troubles. Also, I'd recommendat least getting crimp on connectors if you do decide to get an aftermarket HU. The screw on connectors aren't worth the money, or the time you might save (which may be 10 seconds).
Old Aug 30, 2004
Civic_Racer9's Avatar
(SnOwBoArDeR | FoReVeR)
go to best buy or circuit city and BUY THE PLUG-PLAY WIRE HARNESSES.
so there will be no cutting w/ after market hu
Old Aug 31, 2004
MegaHurtz's Avatar
It's easier and probably cheaper to go with aftermarket, and install is a cinch
jdh022764
18
Nov 3, 2015 06:44 AM
Bricoleur
Sep 9, 2015 12:23 PM
Wiggles
Sep 8, 2015 05:05 PM
MamaBear2015
Sep 4, 2015 09:04 PM
JJ291
Sep 2, 2015 11:49 PM
