Audio help for sound PROs out there
Old Aug 27, 2004
Rx7_Fan's Avatar
Rx7_Fan has a little shameless behaviour in the past
Hey guys,
I have been reading this forum for a while and I know there are some audio PROs in here that are very helpful when they give advices. Please help me.
I am thinking of getting a Clarion DXZ745MP and Infinity Kappa component spreakers. The tweeter will be posted on my front door just like the 2004 civic coupe. I am not looking to bump my system or have it amazing loud, I just want clear and warm music. The type of music I listen to are R&B, RAP, and Trance. I really want a 'stock', OEM look; that's why I chose the clarion, so I can change the head unit color to match my interior oem color of orange. Do you guys recommend a diffrent set of head unit and component speaker systems? If so, let me know, which is the best for my money. I am a college student so really don't have much to spend, maybe $600 max.
Any constructive feedback/post will be greatly appreciated.
Old Aug 27, 2004
brash's Avatar
brash is an unknown quantity at this point
- Do you really need the ability to play MP3s? If not, you can get a nicer deck for your money (or a cheaper one!).
- I would recommend Eclipse or Alpine, or Pioneer, over Clarion.
- It might be worth considering an amp instead of a new head unit. $600 allows for a decent 2 channel amp (Alpine, MTX, Pioneer Premier, etc.) and some good components for the front, and you will notice a very nice improvement in SQ. You might have enough for a used HU if you are willing to try installing yourself, possibly even if you have it installed (cutting it close).
Costs will probably be as follows, not counting install costs:
HU: $100 - $200 (maybe more, depends on features and whether it is new)
Amp: ~$150
Speakers: $100 - $150
Wiring, etc.: $50
Old Aug 27, 2004
auto84's Avatar
I R T3H 1338
auto84 will become famous soon enoughauto84 will become famous soon enough
alpine 7893 or 7995 on ebay $150-175
decent 2 channel $150 (xtant?)
materials $50 (8 ga wiring kit)
Crystal 6 1/2 components $200 (sounddomain)
total $550- $575
Old Aug 27, 2004
I would STRONGLY recommend getting a deck with a decent equalizer built in. I don't know if I could work with anything less than the 13 band my pioneer comes with. But anything more than just treble and bass adjust will help for sound quality. An amp would also help make the speakers sound better, even at lower volumes.
Old Aug 27, 2004
Rx7_Fan's Avatar
If i get an amp, would the wiring be all over the place? I snowboard during the winter and i figure an amp and all the wiring would me messed up when i put my snowboard filled w/ ice and snow during the winter season. Thanks for your help guys. I will look into Alphine or Pioneer since so many of you recommend them. But the INFINITY KAPPA is good right? just different head unit?
Old Aug 28, 2004
Rx7_Fan's Avatar
I think i'm going to replace the Clarion with an alpine CDA-9833. =) Fit w/ inifity kappa. Good choice?
Old Aug 28, 2004
LudlamTheory's Avatar
i boogie for the raindrops
you want stock look, look into nakamichi headunits
Old Aug 28, 2004
Flounder's Avatar
Flounder is an unknown quantity at this point
I can't speak for the Kappas (I'm entirely Eclipse), but the 9833 is a really nice HU, and would be a decent choice if you really don't want to go with an amp. Make sure it is installed correctly (10awg to the battery is recommended, I believe)...the V-Drive internal amp will suck some power.
When I was looking, it came down between the 9833 and my Eclipse 5444. I thought the 5444 was a little warmer in the mid-range, but it was a really close call. You wouldn't be upset with the 9833 (except the price tag, but there's a reason for it), and it would allow you some serious upgrade ability down the road.
Old Aug 28, 2004
I have infinity reference speakers (lower than the kappas), and they sound so much better than stock. Also if you have money left over, I recommend one layer of dynamat in the front door panels to make them sound even better.
Old Aug 28, 2004
faultyscrew's Avatar
faultyscrew is an unknown quantity at this point
I couldn't live without my 13 band on my Eclipse 5444 either. There is an easy mode on the deck with just a 2 band, bass and treble, EQ but it cannot compare to using the larger EQ. It may be best to go used on the HU so you could squeeze something with really good sound into your budget. I'm not sure exactly what you should for on the used market but I would look into used higher-end Eclipse and Alpine decks. Not only will you get a bigger EQ but you will get other features like higher volt pre-outs and such. If you can't afford anything on the high-end new then I would definately go used! Just my take - good luck!
Old Aug 28, 2004
Rx7_Fan's Avatar
Thanks guys, I think I will get the Alphine head unit first, then saves up some money and get the Kappa-s. And maybe later I'll get an amp or a sub later.
Old Aug 29, 2004
Civic_Racer9's Avatar
(SnOwBoArDeR | FoReVeR)
get an alpine hu
infinity kappa series (i got my fronts and rears for 240$ on sounddomain frees shipping too).....DO NOT NEED COMPONENTS.
later get an amp and amp the speakers
wow beautiful sound!!!!!!
Old Aug 29, 2004
PopcornPlaya's Avatar
Electric Boogaloo...
Ludlam beat me to it. I was gonna say that if you wanted the stock look with aftermarket performance to check into nak headunits. the kappa's are alright, but not really worth it if you're not going to amp them.
Old Aug 29, 2004
Rx7_Fan's Avatar
Okay, how about stock head unit and alpine amp with Infinity Kappa? Will it sound good?
Old Aug 29, 2004
Yeah it would. The deck is mostly for tuning the sound, especially if you have an amp already. You may not get the best signal using wires instead of RCA outputs, but it will still sound good. Upgrading speakers should be the first thing you do.
Old Aug 29, 2004
ehh... alpine amps are alright, you could get the same performance at a more reasonable price though, that way you could get an aftermarket deck sooner. I wouldn't worry about the rears anyway, unless you really care about entertaining back seat passengers. I'd concentrate on getting a good comp set for the front and a good clean amp to power them. Rear fill is not necessary.
sch2cm
Jul 21, 2015 09:58 PM
Theshwartz35
Jul 17, 2015 11:13 PM
krazykoncepts
Jul 14, 2015 01:55 PM
