neon kit wiring to headlights
Old Aug 21, 2004
winnerpl's Avatar
winnerpl is an unknown quantity at this point
Hey guys I got a interior neon kit and would like to wire it to my headlights so that if I turn my lights on, the neons willl turn on too. ANy ideas into this? Would the load be too much? (the neon kit uses a 5amp fuse). How would I go about tapping into the front (or rear) lights?
Old Aug 21, 2004
You just have to look for the wires. Honestly, tapping the parking lights would be safer imo. You want the red wire going into the turn signal bulb.
Old Aug 21, 2004
winnerpl's Avatar
that's fine too and I agree it's even better/safer. Plus parking lights are on too when main headlights are on, right?
Old Aug 21, 2004
MegaHurtz's Avatar
tap into the wire u want and connect a relay that way u can use as many neons as u want
Old Aug 21, 2004
winnerpl's Avatar
hmm I'd rather avoid relays since I've had diffuiculty finding one (finally found one at radio shach the thing was tiny and didn't know what to do with it :/). But a relay does make sense since I wouldn't have to strain the regular connection with the extra load.
Old Aug 21, 2004
Neons don't take up much power. I have sidemarkers wired to the parking signal lights, and they're more of a drain than the neons I had.
Old Aug 22, 2004
winnerpl's Avatar
^bump. would like to get more input before I start splitiing wires
Old Aug 22, 2004
Splice away I guess. I don't know exactly how the tails are wired, but there should be a few wires. Don't you coupes have just a regular parking light on the SIDE of the tail? I think you do. Just tap the power of that one. It should only have power and ground wires.
Jeffdp
Jun 18, 2015 06:18 PM
Supramk3
Jun 11, 2015 11:13 AM
DeFiaNT
Dec 3, 2001 07:11 AM
NukeSilo
Nov 20, 2001 05:17 PM
NukeSilo
Nov 4, 2001 09:37 PM
