trunk floor
Old Aug 20, 2004
dannn's Avatar
unique conformist
dannn will become famous soon enough
trunk floor
ok so i want to put in some stuff in the trunk like subs and an amp
how do you guys fasten the wood to the car? like that one big piece of wood that covers the spare tire. how do you prevent it from jumping around and moving?
Old Aug 20, 2004
Mr.Modify's Avatar
the floor board? try velcro....it works really good....i used velcro on my speaker box and dude it was the best thing i ever did!
Old Aug 20, 2004
MegaHurtz's Avatar
Velcro is the easiest solution, or you can do what I did which was create a hinged platform for my box that I bolted to the hump behind the back seat, and then fabricate the rest of the false floor around it
Old Aug 20, 2004
dannn's Avatar
unique conformist
i tried the velcro but it keeps coming off.
the sticky part i mean. the velcro itself was very strong but the adhesive would come off. i will be removing it alot so i think the hinge idea ia good.
Old Aug 20, 2004
MegaHurtz's Avatar
My method also stops your box from being inadverently removed from your trunk
Old Aug 20, 2004
DrivenConcepts's Avatar
Don't Listen To What Anyone Says, It's Ok To Be Jealous
DrivenConcepts should not be trusted
if only i can afford a system
Old Aug 20, 2004
Vinnie's Avatar
Vinnie should not be trustedVinnie should not be trustedVinnie should not be trustedVinnie should not be trusted
I made an entire new trunk floor with stronger wood from home depot. Weighs more but its okay, i like my trunk
Old Aug 20, 2004
brash's Avatar
brash is an unknown quantity at this point
Don't just stick it on, STAPLE it on (or use little nails if you can't use staples).
Old Aug 21, 2004
dannn's Avatar
unique conformist
cool
yea im thinking of getting some half inch or 3/4 inch wood and making a new floorboard that covers the entire trunk.
then cut out a small door that will let me access the spare tire area for more storage.
Old Aug 21, 2004
FuzzBeC00L's Avatar
Fuzzy Boy
you should have another door with ur pop and stuff in it,
Old Aug 24, 2004
sevenplaces's Avatar
I want a TSX!
sevenplaces is on a distinguished road
what I did is buy a cheap rear strut tower brace off ebay. then cut two small slots in the floorboard in front of your sub box and put a strap on each side going around your sub box, under the floorboard thru the cuts and around the strut bar. I cant even move my box around If I go over a speedbump at 50+ mph. works great!
Crazygrlinak
Oct 8, 2015 05:06 PM
Sep 27, 2015 11:33 AM
General DIY
Sep 25, 2015 08:02 PM
Skunkone
Sep 24, 2015 04:38 PM
Michael Durkin
Transmission
Sep 24, 2015 12:35 PM
