Wiring 4 DVC 12's. Need help!
Old Aug 7, 2004
mattlx03's Avatar
mattlx03 is an unknown quantity at this point
What is the best way to wire 4 DVC 12's to one 800w amp?
Old Aug 7, 2004
zen_master's Avatar
what's ur sub?
what's the ohm of each coil?
Old Aug 7, 2004
irishtemper's Avatar
irishtemper has a spectacular aura aboutirishtemper has a spectacular aura about
It will not be very efficiant but here it is.....
Old Aug 7, 2004
can't load the pic
Old Aug 7, 2004
also if it's a 4ohm coil, you will get 2 ohms total off of 4 DVC subs. Better off with 2 amps.
Old Aug 7, 2004
forget my diagram, i messed up.
Old Aug 7, 2004
alex053's Avatar
http://rockfordfosgate.com/rftech/wiringwizard.asp
Old Aug 8, 2004
mattlx03's Avatar
The subs are MB Quart R WC 304. On the bottom it says 2x4 Ohms, so I'm assuming that means 2 Ohms per coil.
Old Aug 8, 2004
mattlx03's Avatar
Or maybe it means each coil is 4 Ohms. 2(coils)x4(ohms).
Old Aug 8, 2004
yes they are 4 ohm coils x 8= 2ohms. Make sure you have a powerful enough amp to run them, you may need a second amp.
Old Aug 8, 2004
zen_master's Avatar
2 x 4ohm, that's good..
my suggestion,
parallel each oil on each speaker.....so, 4 || 4 = 2 ohm
then, find XXX RMS x 2 CH @ 2 ohm amp..
where XXX = watt rms each of your sub....
running at stable 2 ohm is usually the best for many amps.....they can crank the best potential when u run it at 2 ohm.....
SimpleUser
Apr 24, 2021 02:54 AM
Kevinsisco
Aug 31, 2015 12:04 AM
sch2cm
Jul 21, 2015 09:58 PM
CivicsClass101
Jul 9, 2015 11:14 AM
robbie374
Jul 7, 2015 02:56 AM
