Slot port question
Old Jul 22, 2004
fonto's Avatar
The LA Clipper
Slot port question
I have never built a slot ported box before. If I were to build one, would it be ok to build on similiar to the one I am attempting to diagram below...the inside port wall will prolly be about 12 inches or so long and 2 inches wide in abox that is like 25 inches long...or am I way of on a the general structure of a slot ported box (does there need to be more then one port wall)?
____________________
l.......................................l
l..................................l....l
l .................................l....l
l ________________ l....l
....sub 1.........sub 2.............
(the dots are just there to make sure everthing lines up)
Old Jul 23, 2004
Ed's Avatar
Ed
Old Jul 23, 2004
fonto's Avatar
The LA Clipper
Thanks Ed, that is it!!!!! ....my port will probably end up being only about half the legth of the box (because the box will be long).
...anywayz, does anything seem wrong with that setup?
Old Jul 23, 2004
AlpineCivic's Avatar
I have the same style box for my 15". I reccomend it totally! if you build it right it should rock. My port was so long that I had to make an "L" shape into the box and it sounds great. What subs are you gonna use? I can get you the type-x now if your still intrested but from what Im told they only sound good at 60hz and below so you may have to use a mid-range sub.
Old Jul 23, 2004
fonto's Avatar
The LA Clipper
Thanks Wes, but i think I am gonna stick with my IDMaxes. I just dunno if I want to keep it sealed for daily driving or ported, so that I can enter comps. I had it ported for a weekend and it was outragously LOUD (plus I hated the box too)...I dunno
Old Jul 23, 2004
PopcornPlaya's Avatar
Electric Boogaloo...
I'd probably do the port in the center, but that's just me.
Old Jul 23, 2004
fonto's Avatar
The LA Clipper
Yeah, me too...but I need every inch I can get...and that would make the box longer.
Old Jul 23, 2004
WhiteRabbit's Avatar
that boxplan works like a champ, and is very common. if you decide your port needs to be uberlong, you can fold it, like in this picture:
Old Jul 24, 2004
alex053's Avatar
be sure to read up on "Effective Port Length" so that you can get your tuning right
Old Jul 24, 2004
fonto's Avatar
The LA Clipper
That is exactly what I wanne figure out...gimme a link, gimme a link
Old Jul 24, 2004
LudlamTheory's Avatar
i boogie for the raindrops
other way to get tuning right is with a multimeter sir. put the box together sans glue and just trim off or add one as you need for port length.
multimeter at amp outputs, set all equalization to flat, sweep tones, where ac voltage reads absolutely lowest (should dip real quick) is your tuning frequency.
you by chance doing 2.5 @ 28 hz?
also, have you looked into dctt's?
you seem like the type that would adore a dctt
http://www.diysubwoofers.org/prt/dual_chamber.htm
you can tune down low and up high
Old Jul 24, 2004
fonto's Avatar
The LA Clipper
That is an interesting box type...I am looking to have as much output without having to use to much space.
...probably about 2.3-2.5 per sub tuned to between 28-30.
...I may just stayed sealed for now...but start to rebuild my trunk slowley.
Old Jul 24, 2004
Rufus's Avatar
effective port length is easy. Take a tape measure and wrap it through your port from end to end. It just needs to equal the length you're looking for.
burnyd
ECU Fried
May 24, 2018 10:44 PM
4jacks
Aug 17, 2015 01:26 PM
user 84948
Air Conditioning
40
Jul 10, 2015 07:08 PM
Ccoop87
Jul 9, 2015 03:26 PM
ballmich
Jul 9, 2015 11:59 AM
