Power To Trunk...HELP!!!
Old May 28, 2004
supernootz's Avatar
supernootz is a jewel in the roughsupernootz is a jewel in the roughsupernootz is a jewel in the rough
Somebody, please help me out. I need to run a power wire to the trunk area that is switched on with the ignition (or Accessory position). What is the easiest way to do this?!?? TIA!
Old May 28, 2004
supernootz's Avatar
More specifically, is there anything in the back there that I can tap into without having to run wires all the way to the front of the goddamn car?
Old May 28, 2004
Silver_JS5's Avatar
Silver_JS5 is an unknown quantity at this point
if you have a system...put the ground to the ground on an amp, and the positive to the remote of the amp....what are you trying to wire?
Old May 28, 2004
Mystic3030's Avatar
Yup, i'm an A$$hole.
Cig lighter would be easiest...what are you powering? If it's something with a high current draw you are gonna need to use a relay tripped by the ciglighter/ignition and getting power from the battery.
Old May 28, 2004
supernootz's Avatar
No, it is very low amperage draw, it is not for stereo stuff, nor do I have an amp back there.
Old May 29, 2004
tom1178's Avatar
tom1178 is an unknown quantity at this point
Just outta curiosity, what exactly is it that you want to power?
Old May 29, 2004
Silver_JS5's Avatar
if you let us know what you are trying to power and for what reason then we might be able to help you out a bit more.....cause if its for extra lights in the trunk....and since you don't need lights when the trunk is closed....then you can just tap into the trunk light...but what exactly are you trying to hook up and why?
Old May 29, 2004
LudlamTheory's Avatar
i boogie for the raindrops
the only strictly ignition wire youll find with ease is in the steering column.
if you dont mind using an accessory wire, which is also on with ignition, but also when the key is in accessory more, tap off the wire behind the radio
Old May 29, 2004
2k2redcivic's Avatar
2k2redcivic has a spectacular aura about2k2redcivic has a spectacular aura about
the right way to do it is to run a power wire from the column back to the trunk. its accually easier than u think, u can tuck the wire all the way back without takin off n e panels. u really have to be carefull about tapping multipal things (even low voltage) into facory wiring, the tend to get hott even with the factory fuse.
Old Jul 26, 2004
supernootz's Avatar
thanx
jordan1794
General 8th & 9th Gen
May 11, 2019 08:59 PM
kmarcet
Sep 26, 2015 10:25 PM
Dave1984
Jul 22, 2015 06:10 PM
breanna_17
Jul 21, 2015 04:01 PM
