speaker problem
Old May 11, 2004
hondaciv01's Avatar
hondaciv01 is an unknown quantity at this point
speaker problem
a couple days ago my music cut out completely. i have no clue why. it comes on fine when i turn on the car but if i turn or hit any sort of bump it will go out. i thought it was a wiring problem with the hu, but all the connections seemed to be good. also, when the music isn't working, some crackling comes from the rear speakers.
Old May 12, 2004
vicn77's Avatar
vicn77 is an unknown quantity at this point
check your speakers...one of your wires might be pinched causing a short
Old May 13, 2004
up4surf's Avatar
up4surf is an unknown quantity at this point
Looks like a sticky situation. First off, what kind of system do you have? is it stock or after market? If so, what have you done, and by whom? Tell me more info about your system and I will help you with what may be causing the problem.
Old May 15, 2004
catalin's Avatar
catalin is an unknown quantity at this point
I'd say one of the terminals on the rear speakers is either touching the truks tortion bar or the metal surrounding the speaker. Could always be connections at the head unit if it's aftermarket.
Old May 15, 2004
KaZeLL's Avatar
KaZeLL will become famous soon enough
could be the RCA terminal on the board of the amp is cracked, I use to have that problem with a few of my electronic components...if all else fails open up the amp and check the solder points on amp see if there is a fracture there
Old May 15, 2004
Hcivic01Vtec's Avatar
Hcivic01Vtec is an unknown quantity at this point
I wouldnt exactly open up the hu unless you dont have a warranty on it anymore. This sounds like a short somewhere, you have a wire that is touching ground and you need to find where it is.
Old May 17, 2004
hondaciv01's Avatar
whatever went wrong, it just fixed itself. i'm confused but whatever it works
dbagaus
Jun 10, 2015 09:29 AM
SLeePeR012
Jan 7, 2002 12:24 AM
guy
Jan 6, 2002 04:39 PM
djaber
Jan 4, 2002 06:23 PM
PimpBot5000
Nov 26, 2001 07:15 PM
