Remote start help!!! PLEASEEE
Old May 8, 2004
Weathered's Avatar
Weathered is an unknown quantity at this point
OK so this is my problem
I'm installing a remote start for my 2002 ex civic manual trans. The car is able to stay on after i take my key out. it locks my doors, unlocks my doors, the remote even turns to car off after i have stepped out. THE only problem i'm having is that it wont turn on.
does anyone have a clue
I'm thinking it has something to do with my clutch. I would greatly appreciate any feedback i'm in need of it.
Old May 9, 2004
2k2civic's Avatar
Have you disabled the sensor at the clutch pedal? Basically, you gotta connect the two wires at the connector to fool the ECU into thinking the clutch pedal is down and start the car.
Old May 9, 2004
2k2redcivic's Avatar
2k2redcivic has a spectacular aura about2k2redcivic has a spectacular aura about
its the upper connector. just hook up a wire between them and plug it back in.
Old May 10, 2004
custom2k1's Avatar
custom2k1 is an unknown quantity at this point
1. what kind of starter is it?
2. When you hit the button to start it does it power up the
ignition and accessory and then just do nothing or does it not even do that?
Old May 10, 2004
Weathered's Avatar
have a ultra starter 1256m, when i hit the buttom it does not do anything.
Old May 10, 2004
LAKAS187's Avatar
LAKAS187 is an unknown quantity at this point
Yeah it's either your clutch sensor,or your bypass.
Old May 11, 2004
Rufus's Avatar
It could be worse, I just did my 5 speed 03 and had to do the transponder bullshit.
Old May 12, 2004
up4surf's Avatar
up4surf is an unknown quantity at this point
More than likely you will need the transponder unit. Look on your front windows in the corner and see if there is a sticker that indicates that the car is porotected with coded keys. I have a 02 EX and I in the same bost.
Old May 13, 2004
Rufus's Avatar
Just look on your dash. You should have a flashing green key.
Old May 13, 2004
up4surf's Avatar
The flashing green key would be an add on theft deturant system. A transponder key is a chip in the key its self that lets the car start. For the alarm there is a box that you put an extra ket that has the chip in it and the box need to be wired up around the ignition, that will allow the car to start without putting a key in. P.I.T.A
Old May 15, 2004
catalin's Avatar
catalin is an unknown quantity at this point
All 2001 Civics and newer come with factory installed transponder immobilizers.
Civic2002lx
Oct 7, 2015 09:17 AM
MamaBear2015
May 3, 2015 02:17 PM
DaveyD
Mar 28, 2003 12:28 AM
Trey
Jan 6, 2002 02:30 AM
loquito
Nov 12, 2001 07:24 PM
