Molding trunk sides?
Old Mar 10, 2004
Vinnie's Avatar
Vinnie should not be trustedVinnie should not be trustedVinnie should not be trustedVinnie should not be trusted
I want to mold some like side panels into the trunk. I was wondering what kind of material would be best? I want it to fit snuggly but also be rather easy to take out. Kind of like this picture i found. But not in yellow of course.
Old Mar 10, 2004
Vinnie's Avatar
This is exactly what i want to do
Old Mar 10, 2004
WhiteRabbit's Avatar
to mold anything you want, you must come up with the contour, here is the standard way of doing it:
lets say you wanted to make that board that the guy in teh above post did. start with a board say 8 inches square. Now grab a corrugated cardboard box and cut it into a bunch of strips that are a foot long and 2 inches wide or so. they can vary, thats jsut the approximate size.
now take your 8 inch board and set it on teh floor of the trunk, standing on edge, right where his board is. now you jsut gotta make the form fit.
take your strips, and set them on the 8" board and line them up with the contour of the trunk, then stablegun it onto the board, keep doing this around the entire edge of the trunk. then you can remove the board, and trace around the cardboard onto your piece of wood you will cutout for the real thing!
now you have a perfect mold of htat area
Old Mar 10, 2004
nunzio42's Avatar
nunzio42 is an unknown quantity at this point
fiberglass!!!!! I think i am going to do somethign like this soon!!!
Old Mar 10, 2004
Vinnie's Avatar
Thanx rabbit. So after i make the cut out i should have a piece of wood that fits into the area, but it wont have thickness right? Only however thick the wood is? So how would i make it fit the countor on the back of the piece?
Old Mar 10, 2004
Mystic3030's Avatar
Yup, i'm an A$$hole.
I don't get it
Old Mar 10, 2004
if I have time, one of these days I will make a fake one and take pictures, its much easier to see in person.
Old Mar 10, 2004
http://www.7thgencivic.com/forums/sh...hreadid=143971
DerbyDad03
Exterior
May 16, 2021 10:07 AM
Adam925
Nov 19, 2019 10:56 AM
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
mohawkboom
67
Aug 25, 2015 12:28 AM
Youshoe
May 22, 2015 09:36 PM
