whops! i think i messed somethig up...
Old Feb 2, 2004
preliasco's Avatar
preliasco is an unknown quantity at this point
Thumbs down whops! i think i messed somethig up...
ok so heres the deal I had bought this civic used from a dealer, it had an amp with a little sub in the back, worked pretty deciently(for the time being), i proceded to move so i unhooked everything and what have you for more room, just yesterday i finally got a chance to put it back in, i set everything up the way it was befor, but this time the deck doesn't work, its the stock deck, the lights still come on at night and the antitheft red blinking light still does its thing, it takes CDs, but doesn't play them and it can eject, i just can't turn it on so im driving in scilence...is this something easy to reverse or should i finally invest in a real system?
Old Feb 2, 2004
I doubt what you did was the cause, unless you took out the deck for some reason. Just take it back to the dealer and ask them to fix it. If not, you're better off with a new deck. It will make everything sound better anyway.
Old Feb 2, 2004
kjgracing's Avatar
Hail to the king baby
kjgracing will become famous soon enoughkjgracing will become famous soon enough
stock deck or aftermarket deck?
Did you disconnect battery?
Just enter in the code again.
Good Luck
Tedverseti
Apr 23, 2020 01:45 PM
Tyler93
Mar 20, 2016 09:03 PM
Munzy
21
Oct 7, 2015 07:48 AM
Dawit Melese
Oct 4, 2015 08:02 PM
Dsmak
Sep 10, 2015 08:30 PM
