pics of my diamond audio d7 amp...
Old Jan 29, 2004
  #31
slicksivik's Avatar
i kinda like the jl amps better
Old Jan 29, 2004
  #32
slick's Avatar
that little dude
slick will become famous soon enoughslick will become famous soon enough
Here are the specs for the amp, for anyone that cares:
TECHNICAL
Symmetrical Topology, Fully Regulated, Triple-Split-Rail Power Supply Isolated Input Section Utilizing “Quasi-Differential”
Instrumentation Amplifier Technology
Up To 12VRMS Input Signal Voltage Capability (With -12dB Attenuator)
Third-Order 18dB/Octave Butterworth Crossover Topology
Wide Bandwidth/Low Distortion Symmetrical Gain Output Stage
4 oz. (3 oz. on D7152) Gold Plated Copper Circuit Board
High Efficiency Forced-Air Cooling System
Massive 3-Piece Proprietary Heatsink
Solid Copper High-Current Power Distribution Busbars
CONVENIENCE/APPEARANCE
Two 3-Way Fully Variable and Independent Electronic Crossovers in Top-Mount Configuration with Supplied Plexiglass Security Cover
(Separate Independent Crossover for RCA Outputs)
24-Karat Gold Plated Solid Brass, Circuit Board Mounted, 4 Gauge
Direct or Ring Terminal Power/Ground Connector Blocks
24-Karat Gold Plated Solid Brass, Circuit Board Mounted, 10 Gauge Direct or Banana Plug Direct Speaker Connectors
Tinted Plexiglas Circuit Board Viewing Panel
Solid Billet CNC Machined End Panels with Adjustable
Mounting Flanges
SPECIFICATIONS
Frequency Response: 3 – 50,000 Hz
Signal-to-Noise Ratio: 96dB (D7152), 102dB (D7402)
THD: 0.02%
Channel Separation: 80dB
Input Sensitivity: .5 to 12VRMS
Input Impedance: >40kOhms
Power Supply Operating Range: 10 to 16VDC
Old Jan 29, 2004
  #33
syndrome's Avatar
syndrome is an unknown quantity at this point
JL amps do rule
Old Jan 29, 2004
  #34
KeNsHiN's Avatar
LEVA
wow! thats a great looking amp and it's a beast too
Old Jan 29, 2004
  #35
alex053's Avatar
i heard clarion runs the macintosh side of car audio now. anybody else hear this?
Old Jan 30, 2004
  #36
LudlamTheory's Avatar
i boogie for the raindrops
nope. but i do know that the clarion and the arc audio class T amps are teh same design for teh most part, just clarion uses MUCH cheaper parts.
Old Jan 30, 2004
  #37
doubledeuce2k2's Avatar
alright, another FI civic!!! j/k
i'm getting a arc audio class t amp, actually. i like its sleeper look
Old Jan 30, 2004
  #38
arc makes some SWEET amps. i was gonna buy an arc for a while, but then i slightly changed my plans. they dont make an amp with teh power/channels im lookin for...
Fiji-Steve
Dec 4, 2004 07:08 PM
Fiji-Steve
Texas
31
Nov 30, 2004 05:20 PM
KnocturnalEM2
Apr 6, 2004 07:12 PM
FaintReality
South Cali
Apr 29, 2003 02:56 AM
VNlilMAN
Jul 3, 2002 04:26 PM
