FS: High end car audio equipment...
Old Apr 27, 2003
FaintReality's Avatar
FaintReality is an unknown quantity at this point
FS: Lots of new and used high end car audio equipment (got pics)
Alpine MRD-M500 digital mono amp...
I have one of these 500w, digital, mono amps. It has been used approx. 1 month and is in mint condition. The amp has all of the necessary hardware except the two brackets on the rear that help support the cover, in which can be had at any hardware store for a few bucks at the most. I am looking to get $275 firm. For specs and features, please check out www.alpine1.com and/or http://www.crutchfield.com/cgi-bin/...MRDM500&o=m&a=0
Here are some pics of the amp! I had 2 of them in the pics, but sold one a while back...
http://images.cardomain.com/member_i...07_87_full.jpg
http://images.cardomain.com/member_i...07_88_full.jpg
http://images.cardomain.com/member_i...07_89_full.jpg
http://images.cardomain.com/member_i...07_90_full.jpg
http://images.cardomain.com/member_i...07_91_full.jpg
http://images.cardomain.com/member_i...07_93_full.jpg
http://images.cardomain.com/member_i...07_92_full.jpg
10" Adire Audio Brahma...
I have one of these high powered beast that is brand new. It was hooked up free air with 250w to make sure it had no lead slap since It replaced one that I returned with lead slap. This sub can handle 1600w thermal power, and with the custom built enclosure I built for it, it can handle 2200w mechanically before it reaches full linear excursion at 20hz. This sub is arguably one of the best SQ drivers on the market, and has won several SQ and SPL comps. I am looking to get $275 firm. For a list of competitions that the Brahma has won, check out http://www.adireaudio.com/mobile_audio/mobile_audio.htm For indepth info and specs, check out http://www.adireaudio.com/mobile_au...ahma_series.htm
I do not have any pics of this sub, but I do have pics of the old Brahma I returned in the pics with the enclosure I built for it. The new Brahma looks identical, except it has silver binding post instead of the gold, and is brand new with no lead slap.
The enclosure is built out of 3/4" MDF, and with the sub displacement, it will give you a QTC allignment of .707 for optimal SQ. The enclosure has a 1.5" front baffle to support the weight of the driver, and an additional .75" on top of that to flush mount the driver, for a total of a 2.25" baffle. The encloure was then caulked air tight. I then filled in the counter sunk screw heads, primed and painted the enclosure gray. It is very well built, and would not brake or flex if your life depended upon it.
Here are some pics of the enclosure and the old 10" Brahma that I got replaced since it had lead slap.
http://forums.clubrsx.com/attachment...&postid=645482
http://forums.clubrsx.com/attachment...&postid=645488
The hole on the side is for the terminal cup which is now in place and all caulked up... I now have weather stripping on the baffle as well which seals the driver to the enclosure when mounted.
http://forums.clubrsx.com/attachment...&postid=645527
Here is a pic in which you can see how the Brahma is flush mounted. The surround does stick up a lil higher though.
http://forums.clubrsx.com/attachment...&postid=645618
I am looking to get $75 for the enclosure, but if you purchase both the Brahma and enclosure, you can have them for $325.
Please post here, PM me, or email me at faintreality@hotmail.com if you are interested in any of the equipment, have any questions, or would like to come check it out in person.
Dave
Old Apr 29, 2003
bsmiley
Apr 27, 2015 01:27 PM
JDog2001CivicEX
Nov 2, 2001 02:27 PM
