HELP w/ taking off door panel
Old Nov 21, 2003
salokod's Avatar
salokod is an unknown quantity at this point
I'm trying to remove the the door panel and we cannot get the door up and off. I think the door lock (little thing that shows your door is locked or not!?) is in the way and we can't get if off or whatever.
How do we get the panel all the way off, we got it all unlocked and unscrewed. HELP
thanks
spiro
Old Nov 21, 2003
alex053's Avatar
http://www.7thgencivic.com/modules.p...howpage&pid=51
Old Nov 21, 2003
grenloch101056's Avatar
grenloch101056 is an unknown quantity at this point
after u removed the part with the window switch in it, did u remove the two screws behind that? and if you have tweeters, did u pop off the sail panel?
Old Nov 24, 2003
dups's Avatar
dups is an unknown quantity at this point
I've had trouble as well. The funny thing is the first time I took the panels off they came off without trouble, but since then they always are getting caught on stuff and it can be a pain to get them off. Just make sure you've all the clips around the border of the door and there should be a total of 5 screws you must remove. 2 of them behind the latch to open the door, 1 in the window control piece, and then 2 more behind that. If you get all of those it shouldn't be too bad. Good luck!
Old Nov 26, 2003
coop's Avatar
coop is a jewel in the roughcoop is a jewel in the roughcoop is a jewel in the rough
watch the wire harnesses as well - one for your power locks, one for your power windows. I've removed mine several times, getting them back on seems to be a bit harder than getting them off.
Tedverseti
Apr 23, 2020 01:45 PM
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
MamaBear2015
May 18, 2015 07:37 PM
timpan
May 18, 2015 07:06 AM
MamaBear2015
May 3, 2015 02:17 PM
