My Hyperblinker version
Old Nov 5, 2003
Jonauto's Avatar
Jonauto is an unknown quantity at this point
I took the hyperblinker mod DIY and added onto it slightly. Instead of having only one speed that the blinker can run at, or having a variable resistor to change the speed that you cant get to with out taking apart the car, i made everything easily accessable with 2 set speeds and a variable speed. It can run at standard speed, double speed or variable speed. I wired a 2 color led to the switch so i can easily see which setting its on. No light means regular speed, green means double speed, and red means variable (which can double as a strobe light at high setting). What ya think?
double speed
variable speed
Old Nov 6, 2003
doubledeuce2k2's Avatar
seems like a lot of work for it, but it looks clean. props for being original
Old Nov 10, 2003
Jonauto's Avatar
accualy it wasnt that much work, just a few minutes with a pocket knife and a soddering iron.....
Old Nov 11, 2003
pitciv's Avatar
pitciv is an unknown quantity at this point
i like it!! i've never heard of anyone doing that...
i see that the little light above your **** changes colors....but i'm changing subjects...what if you could change the color of the blinker light? that'd be crazy
anyways good job.
Old Nov 12, 2003
Jonauto's Avatar
that could be possible... you would have to make the blinker out of a dual or tri color led cluster. The only problem is taht they are about 2 bucks a piece and it would take about 20 to start to look good.
Old Nov 12, 2003
pitciv's Avatar
what type of lights do the (stock) blinkers use?
Old Nov 12, 2003
Jonauto's Avatar
7443, i just ordered some led replacements yesterday so i can clear the lights...
Old Nov 12, 2003
pitciv's Avatar
that would b sick.....changing the color of the blinker by flipping a switch or hitting a button....so when u see a cop....NO TICKET
shadowfist
Oct 18, 2015 02:38 PM
chiquita.banana
Sep 24, 2015 09:42 AM
LiKEaFeRiO
24
Jul 19, 2004 11:21 PM
symmetry
Jun 25, 2002 10:05 AM
zackde
Feb 21, 2002 10:49 AM
