quick question
Old Oct 9, 2003
dKj's Avatar
dKj
dKj is an unknown quantity at this point
quick question
wud a pg tantrum 1200.1 work with both of the new id max? like i mean if i was to choose 2 or 4 ohm, wud there be any difference because the amp is stable at both 2 and 4 ohms or sumthin like that, and if there is which one wud be better? thanks
Old Oct 9, 2003
LiKEaFeRiO's Avatar
I believe the power output will be different at 2 and 4 ohms.
2 ohms would give you more power.
Whats better depends on your subs impedence.
Old Oct 9, 2003
LudlamTheory's Avatar
i boogie for the raindrops
i believe the PG tantrum 1200.1 puts out full power at both ohm loads.... id still go with dual 2 ohm idmaxes to get a 2 ohm load, you might get a watt or 2 more out of it
Tedverseti
Apr 23, 2020 01:45 PM
civic98?
Aug 13, 2015 01:32 AM
Strycker
Aug 2, 2015 08:40 PM
sam31444
ECU Fried
Jul 20, 2015 08:31 AM
NoobyKid
Jul 13, 2015 07:53 AM
