Electrical Headlight Harness Problems...
Old Oct 8, 2003
2kcivic's Avatar
2kcivic is an unknown quantity at this point
ok, so i have a 2000 honda civic, i run 100w hyper whites, have been for about 3 years now, and just last night, my passenger side bulb quit, when i went to change it, the harness that plugs into the bulb is black/corroded, almost burnt looking, what is this? i get moisture in that headlight sometimes also, could this be the problem?
Old Oct 8, 2003
Cypher's Avatar
Cypher is an unknown quantity at this point
looks like over time the high amount of current through the harness has burned out the plugs someone correct me please if im wrong
Old Oct 8, 2003
Mystic3030's Avatar
Yup, i'm an A$$hole.
^^^ Most likely the problem. You are gonna have to replace your harness.
Old Oct 8, 2003
LudlamTheory's Avatar
i boogie for the raindrops
yup... i velieve our stock headlights are only 55w or so, so if youre nearly doubling the wattage, youll get problems over time
Old Oct 9, 2003
Macko's Avatar
Macko is an unknown quantity at this point
Electric current = Heat...so doubling the wattage means more flow = more heat.. and there goes the harness
mjdiaz89
Jun 21, 2016 09:26 PM
JetsterDajet
Aug 16, 2015 01:56 PM
sch2cm
Jul 21, 2015 09:58 PM
vtec92
HIDs and Retrofitting
Jul 16, 2015 03:55 AM
ZILLA
Jul 5, 2015 05:24 PM
