wiring amps to subs
Old Sep 29, 2003
dKj's Avatar
dKj
dKj is an unknown quantity at this point
wiring amps to subs
if a subwoofer is dvc, cud u have two amps hooked up to one sub, each amp for each coil? for instance, i have 800w amps at 2 ohms, and cud i hook each one up to a coil in any dvc sub at 2 ohms? i wud just need two terminal cups or wutever on the box, i think this is correct if someone cud verify this. thanks
Old Sep 29, 2003
Litespeed's Avatar
Litespeed is an unknown quantity at this point
I'm pretty sure you can't do that. I can't remember why but you can't.
Old Sep 29, 2003
civic01vtec's Avatar
of course u can, but i don't recommed it unless u know what u are doing. All of the spl pros use more amps than subs. The mtx RFL van uses (8) 1000 d's on (4) RFL's.
But in ur instance, ur sub must be dual 2ohm to work. What sub u have that u wanna juice it with 1600 watts. I don't recommend it in ur situation.
Old Sep 29, 2003
alex053's Avatar
truck i helped to build had 16 amps and two subs and I had one 15 with 4 amps in my car for a few days you can run 2 amps per voice coil with the right amps and setup.
Old Sep 30, 2003
dKj's Avatar
dKj
nah, its 800 w max, 600 rms i think? i was thinkin of getting a id max v3, and i guess id have to get the 2 ohm one.
Old Sep 30, 2003
doubledeuce2k2's Avatar
what amp is it? just asking in case you got the specs wrong or misinterpreted them... and you have 2 of this amp, correct?
Old Oct 2, 2003
dKj's Avatar
dKj
yea, i have 2 phoenix gold r8.0:1, specs on the box and website just say 800 max, and then couple online stores ive seen rate it at 600 rms 800 max
Old Oct 2, 2003
JohnDoe's Avatar
JohnDoe is an unknown quantity at this point
some amps allow you to do what's called strapping, which is basically what you're talking about. Not all though so check your amp specs before you try it.
Old Oct 2, 2003
if you got the IDMAXV3D2 then you could hook up one amp to each of the voice coils of the sub. that amp is not gonna be strappable though.
sch2cm
Jul 21, 2015 09:58 PM
Civic65
Jul 19, 2015 10:13 AM
phantommaggot
Engine start problems
Jul 12, 2015 12:55 PM
JustaRhymez
General 7th Gen
Jul 10, 2015 07:12 AM
robbie374
Jul 7, 2015 02:56 AM
