help with hissing
Old Oct 1, 2003
  #31
doubledeuce2k2's Avatar
i think he's refering to stephan king's car that killed people
Old Oct 1, 2003
  #32
Regularjoe's Avatar
Regularjoe is on a distinguished road
Ya, its an old Stephen King one. Basically this car has a mind of its own and so does the radio.
Old Oct 1, 2003
  #33
fonto's Avatar
The LA Clipper
oooooohhhhhhhhhh
Old Oct 1, 2003
  #34
fonto's Avatar
The LA Clipper
ooooooohhhhhhh
Old Oct 1, 2003
  #35
Cyko's Avatar
Cyko is an unknown quantity at this point
Have you upgraded the grounding under the hood? I know I had some mild hissing that went away after adding some 4 guage under the hood and yer sure as hell pushing more watts than me.....
I know that the stock under the hood should be enough, but maybe you've got some corroded wire, ground point or some **** in there. Just thought I'd throw up another idea.....
Old Oct 3, 2003
  #36
fonto's Avatar
The LA Clipper
Good idea! I actually have upgraded most of my wiring related to my soundz under the hood already...but I went ahead and checked it anyway.
Old Nov 17, 2003
  #37
fonto's Avatar
The LA Clipper
Old Nov 17, 2003
  #38
fonto's Avatar
The LA Clipper
Damn, it is finally over!!!!!! The noise is gone!!! I still get MINOR (usual) hissing, but the staticy hiss that i would get after driving my car around is gone (atleast after driving my car around for week with no problems).
So this is how I got rid of the hiss...I sent my crossover back to Audiocontrol, and instead of them saying that they "soldered" a few cold joints, they replaced the inside circuit boards...and guess what, no hiss...damn, i sent my ish in 3 times and finally got it back working correctly. I just wanted to make sure that it was not my fault before I sent it in the 3rd time to Audiocontrol. Damn, it was a pain, but I handled myself very well and didn't go off on anyone at Audiocontrol (mainly because of the reputation that their products have, and because I was not a 100% sure it was the x-over causing my problems).
So all is good, except for the fact that when Audiocontrol replaced my circuit boards they kept my 80 and 20 hrtz modules, and those two were bitches to find in the first place...but they are supposed to mail them to me.
Old Nov 18, 2003
  #39
coop's Avatar
coop is a jewel in the roughcoop is a jewel in the roughcoop is a jewel in the rough
Fonto - I'm a little late responding, but ran into a similar issue with my last vehicle (a 1996 Neon) for which I had an active crossover wired betwween by head unit and amps. Took awhile for me to diagnose - I defeated it using an Ground loop isolator I bought from radio shack. It died in 2001 and the replacement Sony crossover I bought didn't need the isolator - which told me it was simply an issue of a crappy component.
Old Nov 19, 2003
  #40
IDQcivic's Avatar
IDQcivic should not be trusted
I've been getting a "buzz" sound lately, which only is on when my engine is running... I never had this problem before and haven't changed anything and then one day I heard it... it really sucks, hope its not my alternator. I might try some of the suggestions here to see if that helps....
Old Nov 19, 2003
  #41
my buzz went away... i wondered where it went.
but seriously, i redid my ground with a thinner strand wire and moved some wires around. however no matter what i do, somethings make the noise come back: cold weather, blasting music right after starting the car, and driving the car hard.
Metalzone
Sep 16, 2015 12:33 PM
bobsagator
Jun 30, 2005 03:19 AM
fonto
Sep 14, 2004 08:58 PM
dan502
Apr 26, 2004 10:05 PM
eLinux
Aug 5, 2003 07:09 AM
