problem wit sound system
Old Aug 16, 2003
hoho's Avatar
hoho is an unknown quantity at this point
Question problem wit sound system
ok when i first got my system installed, one sub hit harder than the other one and the amp or something would keeep cutting off and i would hear this weird static and grinding noise whenever i turn or step on the gas. i took my car back to get it fixed and they said they jus put in the wrong fuse and a cheap fuse holder. they said they fixed it and when i got it back they worked fine. now it's starting to have problems again. this morning when i was coming to work, i heard this weird sound that kinda sounded like my sub or something was blown but when i looked at the subs they were fine. but now the amp or something is starting to cut off again. it would sometimes miss beats and stuff. i know amps can overheat but i didnt even listen to it for more than 40 mins. does anyone know what's wrong wit my systeM? thanx
Old Aug 16, 2003
Logan3024's Avatar
Could be anything, things i would check
1.RCA wires
2. Ground wire for you amp
3. What kind of OHM load are you giving your amp?
4. Is your amp hot?
5. Possible head unit problem, Maybe a blown RCA output
6. Quality of your amp. Is it a Legacy, Pyramid? If so that could be your problem
7. Check the Sub connections inside the box. Maybe you had 1 sub ran in 8 ohm, and the other run at 4 ohms (for your 1 sub louder than the other)
8. I really dont think changing the fuse helped you, unless your previous one was covered in acid from your battery
9. Not all the time will you be able to "look at your sub and see a problem"
These are just some things i would check. Good luck!
Old Aug 16, 2003
hoho's Avatar
thanx for the help but i do not know anything about stereo system or the wiring so lookin at it myself wont help .....can someone look at my stuff for me please? hehe
Old Aug 17, 2003
hoho's Avatar
anyone? hehe
Old Aug 17, 2003
Mystic3030's Avatar
Yup, i'm an A$$hole.
Drive to New Hampshire on Friday and i'll take a look.
Just take it back to the shop, they should fix whatever the problem is since they installed it.
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
Youshoe
May 22, 2015 09:36 PM
supercivic01
South
Nov 30, 2001 11:27 AM
BabyLX
Nov 16, 2001 05:53 PM
JDock
Nov 9, 2001 08:53 AM
