changing subs from stereo to mono
Old Aug 13, 2003
droppin187s's Avatar
droppin187s is on a distinguished road
Question changing subs from stereo to mono
my subs were hooked up stereo but i want to switch it to monobridged. How would I go about doing this. thanks.
Old Aug 13, 2003
tom1178's Avatar
tom1178 is an unknown quantity at this point
Is your amp bridgeable? There are amps out there that are two channel amps that aren't able to be "bridged" to one channel output.
What amp do you have.....and it would help also to know what kind of subs you are running and what are the ohm loads of your subs........4 ohm, dual 4 ohm, 2 ohm, dual 2 ohm, etc etc.....
Old Aug 13, 2003
alright. 4 ohm Volfenhag Subs, Dual Voice coils, legacy 1600w amplifier.
Old Aug 13, 2003
Bryn's Avatar
Bryn is an unknown quantity at this point
dual 4 ohm voice coils? or dual 8 ohm voice coils?
If dual 4 ohm coils, you could wire in 4 ohm bridged load, which the amp would handle. If dual 8 ohm coils, you could wire subs in 2 ohm configuration, although your amp (LA1470 I assume) can only bridge to a 4 ohm load.
I'll draw a quick picture and see if I can figure out how to post it on here for you wiring schematic, assuming that you have dual 4 ohm subs.
Old Aug 13, 2003
Bryn's Avatar
This will result in a 4-ohm bridged load on your amp using two 4-ohm DVC subs.
Old Aug 13, 2003
alright ill try that Bryn
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
Jeffdp
Aug 5, 2015 11:38 AM
Youngciviboy
Jun 10, 2015 03:49 AM
4 banger
Jun 5, 2015 01:44 AM
SLeePeR012
Jan 7, 2002 12:24 AM
