Help with adjusting crossover
Old Aug 10, 2003
mattymatt's Avatar
mattymatt is an unknown quantity at this point
What's up, I have an Alpine 9815 and I'm trying to use the I-Personalize on the alpine website to adjust the crossover but I'm having a hard time. You have to enter the frequencies of the speaker that you have and they use a scale in which to do this, but it doesn't make much sense to me. On one part of the graph they ask for one number as the frequency and if you look up the frequency for the speakers it will say for example 45HZ-30kHZ, so which one is it? They also ask for the dB of each speaker and it goes from 0 to -12 and I can't find anything in the speaker specifications that comes even remotely close to that. If anyone has used this thing before let me know what they're looking for.
I don't know if this helps but my speakers are:
alpine 6.5 type r's coaxial
alpine 6x9 type r's coaxial
2 alpine 12in type r's 1221d
Old Aug 10, 2003
Mystic3030's Avatar
Yup, i'm an A$$hole.
Post a link to the i-personalize section of Alpine's site....cause I dont see the link, then I can take a look at it and see exactly what they want.
Old Aug 10, 2003
mattymatt's Avatar
There is no link to the I-Personalize because you have to register but I can give you the website link, when you go to the site it will be under Alpine Support. All you have to do to register is give an email address and make up a password.
http://www.alpine-usa.com/html/d2_n_1_n_n.html
Old Aug 10, 2003
Mystic3030's Avatar
OK, it's basically a high pass/low pass crossover system. You set the subwoofer freq. at the highest note you want it to play..generally 80 will do, then you set the slope (how sharply it cuts off at that frequency) You'll have you play with different settings to get it how you like. dB is how much boost it has I think....they dont really explain well on here. since the numbers are negative, I would guess the higher number you input will make that particular component quieter? (my alpine only has time correction, I dont have a xover on mine)
As far as the speakers, you set the hz at the LOWEST freq. you want it to play.....somewhere around 100 is the average for components to save them from too much bass. Then again you set the slope to how sharply you want it to cut that frequency. Higher numbers mean a sharper slope. Then you adjust the dB.
I would play around with different settings till you get it how you like it....theres really no pre-set way you should have it.....
nola000
Engine start problems
63
Feb 17, 2023 09:18 PM
Tedverseti
Sep 29, 2015 05:41 PM
rovafa2002
Sep 28, 2015 06:57 PM
mnewcomb
Air Conditioning
Sep 26, 2015 11:02 PM
TheRiddicles
Sep 21, 2015 01:28 AM
