HELP PLEASE!! w/ turn signal
Old Aug 3, 2003
Htowncivic's Avatar
Htowncivic is an unknown quantity at this point
I just got done wiring my power M3 mirrors with LED, everything works fine, the LED, power functions everything but.....My passenger side turn signal on my headlight doesn't blink. The bulb works, my M3 LED works, the rear turn signal works, and the dash turn signal works. Whenever I put my right turn signal on, the LED, in dash, and rear turn signals blink fast and my front turn signal doesn't blink at all. What could be wrong???
Old Aug 4, 2003
wonderz's Avatar
wonderz is on a distinguished road
rear blinks in "hyper fast" mode while the front doesn't work. I think its a typical case of bad connection. so yeah, check your wires and connections. Once your front is fixed, the "hyper" mode will disappear.
Old Aug 4, 2003
Htowncivic's Avatar
What should I check about my connection? I did the left side exactly how I did the right side. I only have the grounding wire, and a wire running from the LED t-tapped into my turn signal. Where along that series could there be a problem?
Old Aug 4, 2003
custom2k1's Avatar
custom2k1 is an unknown quantity at this point
How do you know that the bulb works? Don't go by the fact that it lights up when turning your parking lights on. Its a dual filament bulb so only half of it could be working (parking lights-yes, turn signal-no). Try changing the bulb and see if your problem goes away.
steveneddy
May 19, 2015 02:39 PM
shaejb15
Apr 26, 2015 07:44 PM
Fastfebur
Apr 22, 2015 01:37 PM
wawacito
May 14, 2002 07:33 PM
my2k1vic
Jan 8, 2002 08:31 PM
