Do I need a Capacitor???
Old Jul 24, 2003
  #31
xtiszx's Avatar
Cracka
xtiszx is an unknown quantity at this point
"Stiffening capacitors can help your amplifiers deliver up to 50% more output on those demanding peak bass notes. Most automotive alternator/battery systems simply lack the ability to produce large amounts of instantaneous power. This is exactly the type of power that car audio amplifiers crave. Adding a stiffening capacitor to your system can add tremendous bass punch and improve transient response. One of the other benefits of stiffening capacitors is the ability to reduce line loss. Line loss is created by the power cable itself. Long runs of power cable associated with mounting amplifiers in automotive trunks creates line loss, especially during deep bass notes. Stiffening capacitors help maintain appropriate system voltages at the amplifier.." i still think thats why you should use a cap, they just summed it up better then i could
Old Jul 24, 2003
  #32
LudlamTheory's Avatar
i boogie for the raindrops
well, like i said, if you can prove it, youve got 5 grand
Old Jul 24, 2003
  #33
alex053's Avatar
spring of 98 mtx didnt have caps....i was there when they bought streetwires...thats when all the cap training started.
whats your name..a good friend of mine worked there at that time
Old Jul 24, 2003
  #34
xtiszx's Avatar
Cracka
i never said they had caps in 98, nor did i say i learned it from mtx, i just stated i worked there, i learned some info on them from co workers, but that was about it, i worked there for about 4 months, but then moved to idaho
i go by curt,
and i wont give my last name, from what i know i was the only curt / curtis that worked there at the time
and im not going to go out of my way to try to prove something like that, im talking from my own use of caps, and what i know, that its better to have it then not on some stereos, and when i installed my cap on my system it took around 15 mins to total charge up, using 4g cable, and i had a volt meter so i knew when it was up to 14v, i wasnt running the car if that matters or does the first charge of it just take longer ?
Old Jul 24, 2003
  #35
Mystic3030's Avatar
Yup, i'm an A$$hole.
Did you use a resistor like on a circuit board when you charged it? That would cause it to take a while.....other than that, it should be instant.
Old Jul 24, 2003
  #36
xtiszx's Avatar
Cracka
ya i use that, i just got off the phone with a few local shops, they all said it depends on the size of the cap and the resistor as to how long it takes
Old Jul 24, 2003
  #37
WhiteRabbit's Avatar
"Adding a stiffening capacitor to your system can add tremendous bass punch and improve transient response
if this is a quote from a company, then perhaps they can give you the evidence to back it up. then you cna take that evidence to richard clark, and collect yoru $5000.
like his post said, even if you live in norway, and a roundtrip plane ticket cost $4000, thats still a grand of profit in yoru pocket. That is, if you really believe in what you say.
Richard Clark certainly does, he has the laws of science behind him.
A capacitor does nothing for audio performance. Headlight Performance, however, is arguable......
Old Jul 24, 2003
  #38
Havok2k1's Avatar
Wicked Pissah Admin
This is great...............
Old Jul 25, 2003
  #39
JohnDoe's Avatar
JohnDoe is an unknown quantity at this point
and everyone knows audio systems are all about headlight performance...
Old Jul 25, 2003
  #40
gotti's Avatar
ya damned right.
Old Jul 25, 2003
  #41
I got some new headlight bulbs, and my spl went up from 144 to 147!
Old Jul 27, 2003
  #42
OMega's Avatar
OMega is an unknown quantity at this point
I like to think of cap as some kind of lake(used in audio only). The "lake" is being fead by a larger body of water at a constant rate. You can draw from this lake little bit at a time with no problems. But the lake can't keep up to high demands because it takes time to fill.
It turns out you could do without the lake if you could get more water out of that larger body. And if you over use that lake it ends up being more trouble then its worth. Even if you made the lake bigger you still stuck with the same amount of water coming into the lake. In the end the lakes ok if you don't put to much demand on it, but you don't realy need it. If your demand is to much just get a larger body of water with a better flow rate......
Old Jul 30, 2003
  #43
omega, id for sure check out that carsound post, its a good read
Old Aug 2, 2003
  #44
OMega's Avatar
Yeah, its a good read. I just like to put a abstract spin on things to help some people get a better understanding. I was taught in basic electronics to think of eletricity as water...
Old Aug 2, 2003
  #45
formulad97's Avatar
formulad97 is an unknown quantity at this point
So should the guy get the Cap or not?
Old Aug 2, 2003
  #46
the guy should get the cap if light dimming at night bugs him. otherwise, its a waste of money.
and also a waste to think that it does anything else. the laws of physics dont lie, ever.
Old Aug 2, 2003
  #47
tom1178's Avatar
tom1178 is an unknown quantity at this point
Dizzle stated to me in a previous post a few weeks ago or so that if my lights are dimming at night my spark plugs are suffering also, anybody care to elaborate on this and the harm it's doing to my engine, because when i trade may car in for a BMW in 4 years i want to make sure the next owner knows my spark plugs used to dim.
Old Jan 3, 2005
  #48
2k2civic's Avatar
Originally Posted by WhiteRabbit
I like headroom, thats why. get a solid strong signal, your equipment doesnt have to run hard, and i cna push my speakers to their limits without pushing the equipment farther than it really really can.
another good reason is that it just plain HURTS to listen to loud music for very long with 3 killowatts!
Unless of course your are running Pyle, Pyramid, Boss, Legacy, or some other crap like he probably is.
I can tell you from my personal experience that a capacitor did absolutely nothing for my system, and the systems of 4 of my friends. I'm not as knowledgable as some of the guys on this forum, however, I do know quite a bit about car audio. One of the first things I learned is that caps do absolutely nothing.
As a matter of fact, I have a cap sitting on my desk. It's a paperweight. One of my cousins gave this to me thinking perhaps I can use it in my car. I haven't even attempted to install it because we all know it's a huge waste of time.
Old Jan 3, 2005
  #49
*shrug* weve delt with this issue many times on this forum. if it didnt work for you, then thats fine, but the fact of the matter is, it does work for a great many more than it doesnt. so, whether its you, your equipment, or your car, (and dont get me wrong, I dont mean to say you have inferior OR superior any of this, merely different!)
again, the fact is that many more people have noticed beneficial effects of a capactor on headlight dimming.
the ones whom it doesnt work for merely speak out more. youve still got the issues!
but no, no need to drag up a thread from 2003 now that its 2005 to start an issue about capacitors.
But I'll tell you what. the cap did nothing for you. furthermore, it did nothing for any of your friends, so they cant use it either. Ill save this thread and shoot you a PM next time I take a trip to irvine, and we can meet up for lunch or something and I'll take it off your hands. no mess, no clutter! clean and easy. I'll find a good home for it so its not buggin you anymore.
Old Jan 3, 2005
  #50
J187's Avatar
J187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of light
FINALLY! Rabbit, you've got an answer. At long last, anxiously checking this post every day since Aug of 03' has paid off. Someone replied!
Old Jan 3, 2005
  #51
M3RKR33's Avatar
M3RKR33 is an unknown quantity at this point
boy this thread was a good read. thx for all the info
btw, im running a 300w RMS sub w/out any cap, and gettin no light dimming as well.
Old Jan 7, 2005
  #52
pyrofoam's Avatar
Love doesn't exist, only blood.
pyrofoam should not be trustedpyrofoam should not be trustedpyrofoam should not be trustedpyrofoam should not be trustedpyrofoam should not be trusted
i'm puttin in two 450w rms subs, figure i'll get sum dimming?
Old Jan 7, 2005
  #53
D5cIvIc's Avatar
ludlam seriously owned YOU!!!
Old Jan 8, 2005
  #54
PopcornPlaya's Avatar
Electric Boogaloo...
To those of you putting in the new replies, please, read through the thread. I linked it in a couple of more recent threads for informational purposes only. This thread is an old thread, but there is a lot of useful information posted in here about the functionality of caps, at least by a select few members here. Don't reply to tell someone a year later that they got owned. Read through it for the information that is on here that is useful, so as not to have to ask the same question, prompting people to give the same answers. The main reason it's here is to learn about the functionality of capacitors. Educational purposes, so to speak...
nguyen949
Oct 2, 2003 02:26 AM
kalipnoi
Aug 31, 2003 12:45 AM
jkim1978
Aug 29, 2003 09:17 PM
Civic2001LX
Apr 27, 2003 11:42 PM
noahnoah
24
Jul 21, 2002 06:47 AM
