Opinions needed
Old Jul 2, 2003
iceman's Avatar
--< GripSpeed Member >--
Opinions needed
Hey wassup i just recently picked up 2 10" kicker solobaric L5 for 175 (is that a good deal? or did i get jipped...and do those subs hit hard)...im just curious as to what kind of amp i should get...and whether or not it will sound clean if i were to do the custom spare tire enclosure ( subs will be in place of the spare tire) or should i just use a box for the 2 10s...any feedback will be appreciated
Old Jul 2, 2003
evilone's Avatar
The Nightraid crew - Sensible Ownage
evilone is a jewel in the roughevilone is a jewel in the roughevilone is a jewel in the roughevilone is a jewel in the rough
I'm really not sure what a good amp to use would be, but as for the subs, 175 isn't bad for a pair of 10's, and they should have some pretty decent thump to them. As for the trunk floor, are you sure you can fit them in? Personally, I'd just keep the box(es) they were in, at least then you know what you're working with.
Old Jul 2, 2003
doubledeuce2k2's Avatar
the square kickers can pound in a small enclosure very nicely. if you can fit them, they can get loud. you'll probably want 250-300RMS to each for really loud, look for an amp that can give you that with whatever impedence your voice coils end up being.
Old Jul 2, 2003
tcostello3's Avatar
tcostello3 is an unknown quantity at this point
If you can. Match them to a Kicker 400.1! Brand specific means something. You don't think they run their subs with Sony amps in the lab do you...No they probably use their amps!
The new Kickers are out I believe. They're NICE!
Old Jul 2, 2003
iceman's Avatar
dooope...and a quick noob question as far as systems concerned..the lower the db the harder the bass right...or am i wrong
Old Jul 2, 2003
fonto's Avatar
The LA Clipper
The higher the db, the louder the bass.
That is actually a very good deal for the subs if they are new. Do you know what year's model they are?
Old Jul 2, 2003
iceman's Avatar
i believe they are the new models...they are the one that franchisedp had...he told me that he parked next to you at one of the meets...hes the one wit the 3 kicker L5
Old Jul 2, 2003
tcostello3's Avatar
Were you by chance thinking the lower the Frequency the Deeper the bass!
Old Jul 2, 2003
fonto's Avatar
The LA Clipper
Yeah, IMO $175 is a good deal.
Old Jul 3, 2003
iceman's Avatar
since u heard those...did those hit hard..or naw
Old Jul 3, 2003
PopcornPlaya's Avatar
Electric Boogaloo...
dB is loudness, higher dB, louder... you're probably thinking about frequency (hz.) lower means deeper bass
Old Jul 3, 2003
fonto's Avatar
The LA Clipper
I honestly can not give you a great assesment of them because I heard them for a second. I know that he had three of them though.
It is really install dependent: placement, sound deadning, power, and (most importantly) box type/specs. He had them in a sealed box, and a ported box may be an option if you want them to get really loud...but it would require a larger box and an infrasonic filter.
I think you live out in the Inland Empire area? Check out the Fry's in Industry if you live near there. They usually have Solo Barics on display that you can play with, but they are usually in a pre-made kicker box (which is prolly ideally set-up to hit hard, and is a perfectly matched box for SPL).
Regardless, I think they are good subs...I would prefer 12"s or 15"s though to get that deep bass, but that is me. Solo 10"s prolly have an equal service area to a typical 12 inch anyway, so I don't know how valid my point is on that. I think that the Solos are Neo magnents so they are prolly pretty light too if your car is set-up for performance.
jbradley4809
Apr 7, 2017 04:23 AM
Jokerhogan
May 9, 2015 02:52 PM
McD
Apr 16, 2015 10:46 AM
Myredjonda
Apr 14, 2015 07:00 PM
aZnVoYCe
Bolt-on Engine Performance
Nov 4, 2001 10:18 AM
