2ohms or 4
The Nightraid crew - Sensible Ownage
It's just a measure of resistance. You can get more power out of a 2 ohm load, but you have to make sure the amp is stable at 2 ohms, otherwise I could overheat/blow/start a small forest fire in your trunk/etc....4 ohm loads run cooler, and pretty much every amp you find is 4 ohm stable, so it's all a matter of personal preference, I guess.....
turboslug
Dec 6, 2005 10:39 PM
