Immobilizer
Old Dec 23, 2017
Immobilizer
Sounds like the key codes got erased.
Click link: http://mastertechmag.com/pdf/2011/09...-antitheft.pdf
Scroll down to find front page of the related service bulletin and read the "symptom" and "probable cause" paragraphs
If you read the entire linked article, it talks about reprogramming (realigning?) the units involved and the car starts and runs, but that process alone doesn't address the issue that caused the memory dump in the first place. If the same scenario happens again, the same result can occur. The new replacement unit listed in the dealers service bulletin is updated to address the issue.
I didn't find the full version on my google search, sorry.
Old Dec 23, 2017
Re: honda civic hybrid 2006 not starting - green key flashing
Key codes got erased.
Immobilizer is not allowing the engine to run because it doesn't recognize your keys.
Immobilizer shuts the engine off at the 2 second mark.
You probably won't get it to run on your own, unless you have a scanner that can access the immobilizer functions and do programming.
First thought is tow it to a Honda dealership.
Have them look up the bulletin I linked, it matches your situation exactly.
Second thought is see if any locksmiths in your area can program Hondas immobilizer keys and system components, see if they can go through the processes described in the linked article.
This might get it going but can't prevent it from happening again.
Maestro
Jul 20, 2020 08:28 AM
pheaton
Jul 30, 2003 04:02 AM
SilverSport
Mar 6, 2003 07:28 PM
kjgracing
Jan 20, 2003 02:56 PM
ekwc
Aug 15, 2002 08:06 PM
